Home > Technical > Which Voltage Sensing Relay
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Going to implement a simple dual battery system - second battery will run the fridge and perhaps phone charging when camping. May also run a rear Scenelite occasionally.
Not sure which brand/amp capacity VSR to get.
1) The Blue Sea ML-ACR looks tasty with its 500Amp load and 2000Amp peak load. But they cost the earth over here (Only USD 180 over the pond, circa GBP 260 here, if you can find one)
2) Victron Cyrix 230Amp one also looks fine. 500 Amp peak load.
3) Multiplicity of others at the 140Amp range e.g. Durite etc
Any advice on which one to go for?
I guess the peak load is only needed if jump starting the vehicle with the VSR connected?
Anyway what are you guys using?
Post #792527 12th Sep 2019 4:04pm
I bought a generic 140amp one and it performs perfectly:
 Darren
Post #792532 12th Sep 2019 4:07pm
Bluest
You need to decide if you want the ability to combine batteries for a self jump start scenario. I think the Victron and T Maxx ones let you do that. If not, the generic Durite/M-Power 140 amp ones do the job ok. I think mine is an M Power one from Simply Split Charge. 2007 110 TDCi Station Wagon XS
Post #792540 12th Sep 2019 4:26pm
kmac
Thanks both - will give it some more thought and decide based on price and availability
Touch wood I have not had to jump start the vehicle ever so maybe that's less of an issue. One can always manually disconnect the VSR when doing so I guess.
Post #792732 13th Sep 2019 9:24am
Yes, you can. The thin black wire in my photo above is the trigger wire, which just needs to be earthed. In its' simplest form, it can be connected to the battery neg terminal but by routing it through a switch you can create a manual override to disable the VSR. Darren
Post #792735 13th Sep 2019 9:32am
I would go with Durite.
Whilst a VSR is good for split charge battery set ups.
I’d be cautious on use for other more sensitive electronic equipment purposes, as there is a cut in voltage and cut off voltage.
On start up the Defender by nature always has a significant voltage drop often circa 8 - 9v during cranking.
So ignition would trigger it, cranking drop it off and then when motor is running it’ll be back on again.
Often in a pretty sudden and extreme manner.
For purposes other than split charging etc I’d rather use a traditional relay as the coil voltage drop out of the switch disconnection is typically lower.
They are also significantly cheaper, easy to change and pretty reliable. (Fining a RMT 12v ignition switched source to trigger is usually not a problem at all either.)
Either way, BlueSea and Durite you won’t go wrong with. Thumbs Up No Guts, No Glory.
Post #792755 13th Sep 2019 10:43am
kmac
Thanks Steve - this is for split charge only.
You mention Blue Sea and Durite - latter is a simple VSR rated to 140amps and costs about 40 quid. Former costs a lot more, main one sold via kits form the likes of Mobile centre is rated at 500Amps continuous and costs almost 300 quid
Post #792776 13th Sep 2019 11:50am
TJH1985
I have the 180 amp CARGO (Bosch) and have no complaints Smile
Comes in at 13.4volts and switch off at 12.6volts so doesn't cut in until a few (ish) seconds after the engine is running.
I have have a secondary fused link that I can connect to bypass it, for if I ever need to jumpstart.
I use it to run a fridge, charge phones, CB etc Thumbs Up
Post #792779 13th Sep 2019 11:58am
That's not the way these VSR's work. The cut in voltage is such that they don't connect until the engine is started and stable, so they don't cut in and out during starting. They're also solid state, so no coil and associated EMI. There's no problem using these in circuit with electronics. Darren
Post #792789 13th Sep 2019 12:52pm
sako243
Not true - just likely to be less intrusive and more easily dealt with by the filters in the electronic power supplies. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #792805 13th Sep 2019 2:30pm
Not true about the coil or the EMI, or both? Confused Darren
Post #792811 13th Sep 2019 2:58pm
sako243
Both and/or one or the other...
Clue is in the name. Voltage sensitive/sensing relay. Normally they'd make a song and dance about it being a solid state relay VSSSR Laughing.
For applications like this it makes more sense to use a good old fashioned relay because once closed realistically it's resistance is effectively 0 ohms. Even the best high current MOSFETs will have an Rds(on) (on state resistance) of a few milliohms which means they'll heat up and you need to get shot of that. At high currents it adds up quickly (in fact squares) so unless you need high speeds then there's no point.
You will also get EMI issues with solid state stuff, in fact in most scenarios (this not being one) its worst. The problem is in the switching, all wiring has inductance which is an opposition to changing current. You in effect build up charge in the cable which then causes an overshoot of the voltage. It's a right sod to deal with and the low frequency stuff unfortunately just means bigger components which means more money which is where cost is usually cut on cheaper electronics.
You can create a much cheaper VSR by simply wiring a relay up to the W (or is it Y) terminal on the alternator. Once the alternator is turning (and in most scenarios the engine is running) then that voltage is no longer shorted to ground and rises to battery which can be used to only turn on the relay when the engine is running. I had this but with an extra switch in parallel to a permanent live so I could connect both batteries if I wanted when the engine was off.
However, most VSRs are a bit more intelligent in that they monitor the voltage and can guess at when the primary battery is charged before switching in the second.
There is a good discussion on a thread involving Si Rafferty on LR4x4 where the idea behind the X-Charge came to fruition which details the pros and cons of each method. Ed
Post #792821 13th Sep 2019 3:18pm
sako243
The best of both worlds would be a microcontroller driving a relay. You could also use something called an ideal diode (built using MOSFETs) which allows you to actually control charge direction should you so desire. Ed
Post #792822 13th Sep 2019 3:21pm
Ah, ok. Interesting. I'd always assumed they were solid state given the way that the operate and that the term 'relay' was being used figuratively. I'm happy to stand corrected though. I guess the relevant point is that they don't suffer from the issues that Steve suggested above, of the voltage dropping in and out on starting and being aggressive to electronics.
I've done exactly this in the past, fitted to a 300tdi Discovery. It used, from memory, a 180amp relay as the base and included a manual override switch (and some LED's to indicate what it was doing). I used it to charge two 100amp batteries in a trailer and it was very effective. The modern VSR's are just easier to install and, as you mention, include some nice monitoring features. Darren
Post #792826 13th Sep 2019 3:38pm
Mo Murphy
I just use a 100 amp relay switched by the alternator. If I need to jump start myself, which I've only ever needed to do once, I plug the jump leads into the Anderson connector and onto the leisure battery and then leave for 30 minutes.
I run the fridge, scenelites and charging points off the leisure battery and has served me well on many trips abroad.
It's not fancy or elegant or trick but it is inexpensive and simple Very Happy
50 Shades of Pennine Grey
Post #792837 13th Sep 2019 4:15pm
