![]() | Home > Technical > Which Voltage Sensing Relay |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1237 ![]() ![]() ![]() |
Bear in mind that the diode across the coil will only suppress fly-back voltages on the circuit activating the relay. Not any fly-back generated from the contactor suddenly disconnecting any load.
You'll also need a diode rated for >~5W (at least a peak rating) given P=VI=14*0.3=4.2W. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5854 ![]() ![]() |
I’ve fitted Durite VSR to three Land Rovers now, and never had an issue with them. Very simple to install and require not maintenance or operation.
Joins batteries at 13.3v Disconnects at 12.6v They also have a 5 second delay in operation so won’t keep flicking on and off. If, which I never have, needed to jump start myself I would just join my batteries physically as they are next to each other. https://www.simplysplitcharge.co.uk/0-727-...-charge-vw |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
why not get a battery to battery charger like those offered by Ctek. Much better IMO due to the charging profiles offered by Ctek, which enables the battery to be fully charged correctly. Leisure batteries don't charge that well from the alternator.
Gilloverland Member Since: 12 Nov 2017 Location: Yorkshire Posts: 61 ![]() ![]() |
Bit of a price difference though !
Its a proper job though, and you can add solar or whatever if need be
