Home > Maintenance & Modifications > Centre dash lighting. (bulb change) With pictures. |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 |
Did we find out if the 2.2 puma was using LED?
One idea for fitting LED is to sand down the end of the LED so the light is thrown out and not so directional. |
7th Mar 2016 3:02pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20359 |
No one has confirmed that I'm aware of?
I thought I heard rumour it was just the I instrument cluster or something along those lines! |
7th Mar 2016 5:36pm |
smudger100 Member Since: 25 Jun 2013 Location: Gloucestershire Posts: 19 |
Brilliant! Thank you very much.
12th May 2017 10:15am |
$W33T $0U7H3RN $UG4R
š¬š§š“ó §ó ¢ó „ó ®ó §ó æš“ó §ó ¢ó ·ó ¬ó ³ó æš“ó §ó ¢ó ³ó £ó “ó æš®šŖšŗšøā½ļøš¢ļøāļøš§°šŖ |
12th May 2017 10:17am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
I've got a few bulbs to replace.
I suspect the one behind fan speed is shot. If I turn the fan onto speed 1 no light, speed 2 no light, speed 3 and it lights up.....I can then move the slider back to speed 1 and it stays on also does the hazard warning lights switch illuminate - mine doesn't but I seem to recall it used to ? if so where the light / lamp for that? thanks, |
13th Jul 2017 4:20pm |
I think the hazard light needs replacing as a unit, IIRC there is an in-built LED but I may be wrong.
Most of the bulbs are okay and quite easy to get at for the rest. $W33T $0U7H3RN $UG4R š¬š§š“ó §ó ¢ó „ó ®ó §ó æš“ó §ó ¢ó ·ó ¬ó ³ó æš“ó §ó ¢ó ³ó £ó “ó æš®šŖšŗšøā½ļøš¢ļøāļøš§°šŖ |
13th Jul 2017 4:29pm |
The hazard switch has a bulb, so switch does not need to be replaced as an entire unit. There is a older thread about it on here which you can try to search. Sorry, can't look it up right now.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
13th Jul 2017 4:48pm |
Here is the thread with all info needed.
Eric http://www.defender2.net/forum/topic12482....witch+bulb You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
13th Jul 2017 6:38pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 736 |
Reviving this as I need to replace the bulbs in the center console, I'm presuming that the parts numbers are still current? If so, I'll be needing 5 of them for the center console cluster? What about the ring around the lighter socket, that has a light behind it too, right? If there is a light behind there somewhere, how does one go about replacing it? I tried looking for threads on that and found none.
Thanks! |
8th May 2019 2:01am |
I have a feeling the lighter socket has a captive bulb, I could be wrong though.
Personally Iām happy with my BlueSea12v socket. Without lighting. $W33T $0U7H3RN $UG4R š¬š§š“ó §ó ¢ó „ó ®ó §ó æš“ó §ó ¢ó ·ó ¬ó ³ó æš“ó §ó ¢ó ³ó £ó “ó æš®šŖšŗšøā½ļøš¢ļøāļøš§°šŖ |
8th May 2019 11:48am |
Hi custom90steve,
As much as I'd like to change that out to BlueSea USB sockets, I still need the lighter type socket for some accessories that I use though I'm planning to strategically place a remote socket closer to the accessories in question to make things a bit simpler and to eliminate the various wires crisscrossing in the cockpit. So better to replace the entire lighter socket then? Confirming 5 bulbs for the center console sans lighter socket, correct? |
9th May 2019 6:08am |
Well, the time has come where a few centre dash bulbs have gone again.
Reading though my thread again, I can't remember how many bulbs there was any more. I think it was 6 total, looking back at Blackwolfs post. I should have counted myself too at the time and reported back. As some time has gone by, has anyone had any success with SMD LED's? Perhaps the patchy light output is no longer an issue. Anyone have any views on this? Luckily the centre dash coming out I'm doing anyway soon, so not a concern but bloomin annoying all the same. $W33T $0U7H3RN $UG4R š¬š§š“ó §ó ¢ó „ó ®ó §ó æš“ó §ó ¢ó ·ó ¬ó ³ó æš“ó §ó ¢ó ³ó £ó “ó æš®šŖšŗšøā½ļøš¢ļøāļøš§°šŖ |
9th Sep 2019 8:25pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 817 |
I know its an old thread, but can the knobs be removed easily on the heater panel, Santa brought me the optimall knobs, the headlight adjustment one is fine, but the header ones dont want to pull off from what I can see and not seen any guide on the internet. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
13th Jan 2022 6:56pm |
