Home > Puma (Tdci) > Clutch sensor
Page 2 of 2 <12
PaulMc
BogMonster wrote:
Any idea what the high-low plugs are? I don't think they are the same? Similar sort of thing but they don't have the metal clip.
The high-low switch uses a Sumitomo HW sealed series 3-way female connector (YPC10181).
This is available from Land Rover as YPC10181 - but, without terminals, seals, or terminal retainer, for an extortionate price of around £10.00 Shocked
I can supply both the male and female 3-way connectors from the Sumitomo HW series, complete with terminals, seals and retainer (and cavity blanks, if needed), for a much better price - and, I'm happy to post anywhere in the world. Paul.
Post #747060 23rd Dec 2018 5:10pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
I'm now thoroughly confused about the logic of this circuit...
All the advice is that the clutch switch is normally closed, and opens when the clutch is depressed, which is supported by what the workshop manual says.
Mine does the opposite - tested with a multimeter across the two pins at the switch, it's normally open and closes when the clutch is depressed more than about half an inch, which is the wrong way around...
This appears to be backed up with the BAS tool, which has the 'TCM - Clutch pedal position top of travel' as False when the clutch is released, and True when it is depressed - the opposite to what I would expect to see.
So I disconnected it and bridged across the plug - the pedal becomes like stepping on a landmine - the slightest movement on or off the throttle demonstrates all the backlash in the transmission at once.
Then disconnected and open circuit - the opposite effect - massive rev hang on up-changes (2-3 second delay before the revs start to die back).
I can't see variations in the operation of the circuit in later vehicles (mine's a 2015) - does anybody know any different? ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #750302 10th Jan 2019 1:09pm
BogMonster
Found a new part to test at the dealer, and apparently they are all the same from 2007 on.
The workshop manual is wrong - the switch is normally open, tested across the pins with a meter.
Still can't explain why it shows the wrong way around on the diagnostic, but that's how it works. ---
Post #750309 10th Jan 2019 1:59pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
ericvv wrote:
custom90steve wrote:
Much better than before, and no gear change Rev hang or change lag like before.
Huh? Gear change rev hang? That’s a 2.2 feature only. The 2.4 never had that.
Eric
Everyone says that but actually whilst it isn't a factory feature of the 2.4 it is a feature all the same. Mine got really bad a while back, lubricating everything in the clutch housing helped. I'm now convinced I need to change (or disconnect) the switch because my rev hang is awful again. As I dip the clutch the revs rise by approx 500rpm from where they were and drop a few seconds later. Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #750322 10th Jan 2019 3:17pm
Hal
Hi Ozzie1989
Did you ever get this resolved? My 2.4 2011 s/w has just started doing exactly what you describe - dip clutch, revs go up a few hundred and then down again.
Only seems to happen changing first to second, but i get the feeling that revs don't drop away like they used to in higher gear changes
Anyone else with a 2.4 puma seen this?
Thx
Hal
Post #790318 3rd Sep 2019 7:35pm
It will be a failing clutch switch.
If your getting backlash with it bridged then you have excessive drivetrain wear, the clutch switch delay / hang masks that wear and tear and if anything giving a drivetrain input that's is not smooth is going to extend and add to drivetrain wear by far.
You must slow down going on to the power when going into gear, also it should be in gear before you apply the power.
I've never had a problem since I have bridged mine, it drives better than ever and oh so much smoother with driver input rather than ECU screwing over every gear change creating unstable on/off irregular torque.
That will definitely increase wear and tear, and make sure going though the gears a pleasure. WeWillWin🇬🇧🇺🇸
Post #790336 3rd Sep 2019 8:13pm
Hal
Thanks custom90steve
Does the 2.4 have a clutch switch? I've been through the w/s manual page by page and cant see it.
Any idea where it is? I've had the clutch pedal cover off in the past to grease everything and cant remember seeing anything around there.
Post #790340 3rd Sep 2019 8:20pm
htb2
Wales
If its the same as a TD5 location. its on the output pipe from the clutch master cylinder
Post #790346 3rd Sep 2019 8:30pm
Yep, the 2.4 has one.
It's located near the bulkhead just to the right of the brake master cylinder, to the left of the coolant expansion tank.
You will see the black plastic, connector with two wires exiting it.
This is a 2.2 motor I think but it is located in the same place on 2.4's too.
As I mentioned previously, you cannot just disconnect it on a 2.4 or 2.2.
You can on a TD5 I believe, but not these. WeWillWin🇬🇧🇺🇸
Post #790351 3rd Sep 2019 8:51pm
Hal
Thanks!
Found it also on connector c0667r in electrical connector manual
Hal
Post #790386 3rd Sep 2019 9:44pm
Zed
Hal wrote:
Hi Ozzie1989
Thx
Hal
Post #790387 3rd Sep 2019 9:49pm
90 Dreamer
What is it supposed to achieve??
Post #790388 3rd Sep 2019 9:50pm
Page 2 of 2 <12
