Home > Puma (Tdci) > Intermediate shaft O ring change
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
When changing the T/C intermediate shaft in the TDCi is it possible to change it by tapping the shaft out enough to expose the o ring and tapping it back in and tightening the nut to it's original position or is it better to replace the crush tube?.
Post #790061 2nd Sep 2019 11:47am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
The WSM states that the TB on the Puma uses a collapsible spacer, yet all the ones I've seen had a fix length spacer from factory, so should be fine... I guess. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #790082 2nd Sep 2019 1:24pm
TD5 and TDCi versions of the LT230 don't use crush tubes, they have select-to-fit rigid spacers. On these boxes provided that you don't changes the intermediate shaft bearings there should be no problem re-using the existing tube. If the box is very high mileage and the bearings are worn, the preload will have reduced through wear and will stay reduced on reassembly.
if you fit new bearings then you should either convert to the crush tube type spacer, or remeasure the intermediate gear assembly and bearing for a new select-to-fit spacer. The latter isn't difficult but does require a certain amount of slightly specialised measuring equipment (a surface place, micrometer, and suitable micrometer depth gauge).
Post #790083 2nd Sep 2019 1:30pm
keef9t
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
So, is it possible to replace the 'O' ring by tapping out just enough to get at and then re-tightening up, on a Tdci Puma.
Post #790384 3rd Sep 2019 8:42pm
Should be. Unfortunately you still have to remove the transfer box first.
Post #790408 3rd Sep 2019 9:27pm
PAT303
Just an update, I slide the T/C back on 10mmx120mm bolts enough to get to the shaft, it was quite easy to do in the end, the original o ring was rock hard and squared off. Interesting enough the nut wasn't staked but a new o ring fitted, a lot of sealant applied, just on this I used permatec sealant that is made especially for use with oils that contain friction modifiers, this is the third time this job has been done and I'm thinking one of my issue's is the sealant is breaking down which isn't helping. Anyway it's sitting on my driveway waiting for the sealant to cure which it does completely after 24hrs and hopefully it will have no more leaks, I will give an update tomorrow.
Post #793904 18th Sep 2019 11:25pm
PAT303
Miracles do happen, my transfer case is not leaking, YYEEESSSS.
Post #794628 22nd Sep 2019 10:54pm
PAT303
Well that was short lived, damn thing is leaking just as bad as ever.
Post #803364 24th Nov 2019 5:18am
hank
Laughing have you considered sleeving the casing?
Appreciate this would require full strip down rather than the quick fix you had anticipated > 110 XS Double Cab
Post #803365 24th Nov 2019 6:16am
Retroanaconda
Sleeved casing is the only proper fix I’m afraid. Been putting mine off for months but it’ll need doing at some point Sad
Post #803367 24th Nov 2019 7:23am
Oldowner
Every lt230 I have stripped down (20 plus) has had a degree of wear in the casing - the intermediate shaft hole doesn’t necessarily ovalise visibly however it always seems to have a groove worn in it from where the o ring seats, which prevents a new o ring from seating correctly.
Only real fix is sleeved case from Ashcroft. I fit a HD intermediate shaft too.
Post #803368 24th Nov 2019 7:31am
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
Pat there is a mod that installs a penny washer to seal the case.
Still requires the box to be stripped but it does not leak.
Mark
Post #803373 24th Nov 2019 8:29am
PAT303
Mate, where can I get one of those penny washers
Post #803458 24th Nov 2019 11:06pm
PAT303
I was hoping I could get it to seal until rebuild time, I was even thinking of filling it with mineral oil instead of synthetic and change it more often.
Post #803459 24th Nov 2019 11:09pm
Big Harold
https://www.allfourx4.com.au/?cawelaid=720...BcQAvD_BwE
Part# NGCP3150 Core, plug dome $10
The case needs a small step machined into it and I took a couple of mm off the end of the Intermediate shaft.
Mark
Post #803463 24th Nov 2019 11:33pm
