Home > Puma (Tdci) > Intermediate shaft O ring change
Page 2 of 2 <12
MadTom
Machining the hole in casing, adding a sleeve a slightly machining the shaft is not so hard work. I was able to do it at home with small mill and lathe. I think, it is the only right solution. Oval hole in casing also means change in gear teath position. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #803469 25th Nov 2019 7:49am
hank
Big Harold wrote:
https://www.allfourx4.com.au/?cawelaid=720...BcQAvD_BwE
Part# NGCP3150 Core, plug dome $10
The case needs a small step machined into it and I took a couple of mm off the end of the Intermediate shaft.
Mark
Interested to see these but can't find them on the website > 110 XS Double Cab
Post #803473 25th Nov 2019 8:48am
Page 2 of 2 <12
