Home > Tdi > 200tdi lt77 gearbox fitted to 300tdi engine
big ives
I have searched and cant find an answer, i have googled and also cant find a yes/no answer
will a disco 1 lt77 gearbox fit to a disco 1 300tdi engine?
is it a direct fit? or will i need to Censored about to get it to fit?
as always thanks for your help 2016 Discovery 4
1989 90 CSW V8 (fully rebuilt and running like a dream)
1996 defender tray back fully rebuilt/loaded for challenge events
Post #789430 30th Aug 2019 6:14am
ickle
If it’s in a defender, doesn’t a disco box have the gearstick too far back?
Post #789438 30th Aug 2019 7:00am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
to fit an R380 to a 200tdi you need a 'stumpy' bell-housing that's shorter.
Going the other way with fitting an LT77 to 300tdi I don't know, but why would you, it's a downgrade. Ashcrofts whould know the answer
Post #789463 30th Aug 2019 8:59am
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Discovery"s have the long bell housing and pinion shaft, thats why the gearstick is back near driver, i had an Lt 77 fitted to a 300tdi. so splines must be same, just check brfore you fit, , i have also put a Discovery LT380 IN A DEFENDER, you have to change the front shaft & bellhousing, to the shorter defender one , thats a box split jobby.
Post #789644 30th Aug 2019 8:43pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
I think some additional info on what you’re wanting to do with the engine/gearbox combo would be helpful.
A few quick answers for the meantime…
Will the LT77 fit the 300tdi? Yes, it will be a direct fit.
Will it fit straight in a defender? No, as has been mentioned the disco gearstick is in a further back location on the gearbox, among other complications depending on current engine/gbox.
Post #790114 2nd Sep 2019 4:41pm
