![]() | Home > Wheels & Tyres > Wheel balancing - is it always necessary? |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 324 ![]() ![]() ![]() |
I have a static balance set up.
I actually have 2 setups of superfine free running bearings with hubs on that are balanced. I normally manage to rig something up to fit any wheel centre diameter, I then clock it with a dti to make sure it is running true. And of course re-balance the setup. About a month ago I did a bit of tyre and tube shuffling; Removed 11 tyres, Half removed 2 tyres and fitted tubes to them. Fitted 3 tyres with tubes. Then balanced the 6. This was all because I have tube type rims and Didn’t have tubes in 4 of the 5. Anyway, back to the question. I checked the balance on a couple of the assemblies beforehand and one appeared to have 80 grams 120 degrees out. I had no wobble before touching anything. I have however balanced them all before fitting back on, I still have no wobble. In general wheel balance wobble is in the 40-60 mph region but this is size dependent. |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1814 ![]() ![]() ![]() |
The wider and more offset you go any in balance will be magnified - my 8.5" with 285's on a zero offset are a b4st4rd!
But the tyre place in Evesham have no problems balancing them, I wait in the workshop tell the fitter they have to be perfect due to the offset and give him a drink after and all is good - surprised your supplier couldn't balance them, never had that before even years ago with 12" banded steels on a 5 stud VW beach buggy! Keith |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
No point normally if used off road. Any off road use will dislodge weights or just knock the wheel tyre about enough to change the balance. Would only consider it if I had bad vibrations caused by wheel imbalances. 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17594 ![]() ![]() ![]() |
When I had my 255/85x16 BFG KM2 muds fitted to my Blindos the tyre place couldn't mount them on the balancer and offered balance beads instead, but suggested trying them without balancing first which is what I did.
To my surprise they were perfect. Like all mud tyres, as they have worn the balance has chaned, and I ended up putting about 10oz of beads in each tyre. |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1233 ![]() ![]() ![]() |
Really? I've used mine extensively off-road and never lost a weight or knocked the tyre with respect to the wheel. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 920 ![]() ![]() |
I've got my Wolfs fitted now and on a quick road test up our local dual carriageway at speeds up to 70mph, there's no vibration, in fact nothing at all to worry about.
I'll admit I'm relieved! |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 747 ![]() ![]() ![]() |
I just had new tires fitted two weeks ago. Pirelli Scorpion MTs in 235/85/R16 on Boost wheels. I wanted to balance all 4 tires but the guys at the shop said I only needed to balance just the fronts for now and just balance the rears when I have them rotated down the line. Drove great even up to 120 kph.
I did a trail last Sunday and crashed into a boulder as we were trying to get ahead of a flash flood due to storm rains. Mangled my steering guard (reinforced bar type), dented the front diff cover (no diff guards yet but I'm definitely getting them now!), haven't fully check the driveline yet, rear step and right rear mud flaps are bent out of shape. Steering wheel is now off center by a few degrees but drives straight still if you point it appropriately and I get a slight steering wheel wobble when hitting 100 kph and above. |
