Home > Td5 > td5 power down |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1115 |
lack of power when driven doesnt rev past 3000rpm anyone got any ideas ?
22nd Aug 2019 7:19pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Could be anything really.
Start with air filter, pipework etc. Then try turbo wastegate actuator for sticking Then try unplugging the maf sensor and see if things improve 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
22nd Aug 2019 7:28pm |
many thanks .
Its a w reg , no smoke at all funny thing the brake pedal goes to the floor now , might not connected . |
22nd Aug 2019 7:41pm |
Unplug the maf and see if the power comes back Ray
22nd Aug 2019 7:52pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5697 |
Just thinking out loud.
Brakes aren’t stuck on are they? So can’t drive at full revs? Just trying to tie up with sudden brake failure? Brake wise is fluid level ok? If not check pipe along rear axle. |
22nd Aug 2019 8:02pm |
master cylinder failed or you flex brake pipe failed |
22nd Aug 2019 8:11pm |
turnah Member Since: 30 Sep 2018 Location: Lancashire Posts: 40 |
I had a similar problem caused by a combination of gunked up MAP, duff MAF, bit of oil in red ecu plug and a fuel connection to the engine (can't remember the exact term) that needed replacing.
Every few months I need to clean the MAP to regain full power now. Think most of this has been said but this was just my experience and helped by the good folks on here to identify. |
30th Aug 2019 4:42pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 556 |
Make sure the fuel pump is working, had a Discovery Td5 and the pump was not working but would run and give similar symptoms to you, not revving past 3k etc.
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
30th Aug 2019 8:03pm |
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 238 |
Sounds exactly like when my fuel pump died. If you hit the tank a few times on mine it jumped back into life.
Does the fuel pump run when you first turn on the ignition? |
30th Aug 2019 9:48pm |
Fuel pump, that's the one I was after (above). Mine made the priming noise but for too long and varying degrees of loudness when it packed in.
30th Aug 2019 9:50pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I had the same problem 2 weeks ago. Lack off power, not reving past 2700 orso. And yes it was the fuel pump.
I expected that the engine wouldn't run without the pump but is does. The new pump is a lot quieter. So it probably was telling me it was dying only I didn't understand him. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
31st Aug 2019 8:49pm |
