![]() | Home > Maintenance & Modifications > Td5 air conditioning illumination? |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 932 ![]() ![]() ![]() |
Hi, I believe the control panel is supposed to illuminate on the air conditioning, can anyone confirm this?
Edit After more googling I found this useful link on another forum, it seems it is supposed to be illuminated, however it looks like the bulbs are soldered in https://www.lrukforums.com/threads/defende...nt.246129/ Unfortunately no information on what bulbs were used as replacements... Thanks Mike |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
OMG! I have never seen the A/C unit illuminated, thought it was always just dark.
This is good, and bad all at the same time. Now I have to figure out how to get buns and get the lights working. ![]() my renovation thread: http://www.defender2.net/forum/topic40792.html |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 363 ![]() ![]() ![]() |
Mine used to light up after a few taps. Doesn't do it anymore.
Sorry! I never realised they were illuminated either until I found a post about it by accident, damn internet!
![]() It's a relatively easy job to do but just don't know what bulbs are required at present so slightly frustrating! Think these may be ok but not sure? https://www.rapidonline.com/barthelme-2110...en-57-6825 |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1001 ![]() ![]() ![]() |
Damm yet another job neither of my land rover ac control panel light up so that twice I will have to do this
![]() Defender 90 Defender 110 XS Cupra 290 |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
i think I posted some pics a few years ago. the bulbs are not easy to change as they are small capless bulbs that are soldered in place.
Patrick here is the link...it wasnt me that posted pics though...... https://www.defender2.net/forum/topic35096.html |
Some useful information here thanks
![]() So the bulbs are 12v / 0.5watt types so those in the link I put in should be ok according to the tech spec? https://www.rapidonline.com/barthelme-2110...en-57-6825 |
kyvlle Member Since: 22 Jul 2016 Location: Essex Posts: 67 ![]() ![]() ![]() |
Thanks for this info! I was wondering for awhile what lights up and what doesn't in mine! Another job on the list!
Yup same here, lack of illumination on the AC switches. Mind you coming from a 1992 Defender before this 2003 I was completely oblivious for at least 18 months to the fact that the heater controls on the dash were meant to be illuminated
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
Sigh. Another job for the list
![]() As the lamps are soldered to the board then they're ideal candidates for an LED. Don't forget the series resistor... R=(Vs-Vf)/I where Vs = 12V, Vf = the forward voltage drop of the LED and I = the desired current for the LED. |
Hi all, as an update, I managed to source some 2.5cm Led strips in the blue and green colour, they are 12v rated so no issues with having to get resistors too.
![]() Click image to enlarge I purchased these from eBay so will see how they go, just needed to cut the wires down to the required length and solder on, seems fine so far and nice and bright. |
Can a small LED be used?
Most of the single led bulbs that I could find were lower voltage so you would need a resistor too, the strips seemed like an easy option, I assume they have a resistor built into the strip circuit.
Hi MikeC. Can you provide some details on the led strips and the fitting please?
This appears to be "the solution"... ![]() ![]() ![]() |
