Home > Maintenance & Modifications > Td5 air conditioning illumination? |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 928 |
Hi yes of course, this is an eBay link to what I eventually managed to find with many different searches! Oddly it's under dolls house lighting!
They are just flexible led strips in various lengths and colours, rated for 9 - 12v DC. The 2.5cm is spot on size wise. They have a length of cable that you will need to trim right down so it fits in the module. Then solder connections on ensuring they are the right way round. Test them first before soldering. Bend the strip so the leds face the panel inside the switch module and shines through. Fiddly and a bit non standard but I figured it was pointless replacing with filaments again as they won't last long. I could not seem to find single led solder type bulbs that were rated for 12v so this seemed to be best compromise. Hopefully they will last! Link below on eBay item https://www.ebay.co.uk/sch/i.html?_ from=R40&_trksid=p2380057.m4084.l1313.TR12.TRC2.A0.H0.Xdolls+house+mini.TRS0&_nkw=dolls+house+mini+led+strips If that doesn't work just search for dolls house mini led or similar should bring it up. |
13th Sep 2019 8:26am |
Link did not work, but suspect these are the bad boys... https://www.ebay.co.uk/itm/Dolls-House-Min...0941081247
Great find |
13th Sep 2019 8:38am |
That's them! Good luck
13th Sep 2019 8:41am |
