![]() | Home > Td5 > problem starting TD5 90 |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 960 ![]() ![]() ![]() |
Sounds like your starter solenoid may need rebuilding. Has nothing to do with locking and unlocking that might be just coincidental. Its actually turning the key a few times that gets it to start by energizing the solenoid a few times. Worth considering looking at it. Its an easy and cheap fix.
Good luck ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
rillas Member Since: 27 May 2012 Location: warilla nsw 2528 Posts: 16 ![]() ![]() ![]() |
Thanks I had that thought but now I now will do tomorrow
stigomery Member Since: 10 May 2016 Location: Cambridge Posts: 277 ![]() ![]() ![]() |
if it's a sticky solenoid, try thumping it with a lump of wood to free it up... worked for me for a while... but ultimately it will need rebuilt, kits on ebay for about a tenner I think...
Stig |
Thanks
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 176 ![]() ![]() ![]() |
Had the same problem a few months ago, it was the starter connection onto the solenoid it was loose and covered in oil and road dirt, cut an inch off the cable put on a new crimp and cleaned the connection on the solenoid no more problems. nobody is perfect but being Scottish is a start
