![]() | Home > Expedition & Overland > Africa Overland - Sankey MK3 |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2188 ![]() ![]() ![]() |
Not long now then........
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10872 ![]() ![]() |
Taking shape
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1366 ![]() ![]() |
Good work, I need to do the same with extending the chassis of mine as it can get a bit of a wiggle on when towing.
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 ![]() ![]() ![]() |
Finally launched our blog to go along with our Instagram page;
https://defenderadventure.eu/ ![]() |
Quick update on progress...
The first of the panels have been cut and prepared. ![]() Click image to enlarge ![]() Click image to enlarge We are using a breathable waterproof paint/stain on the inside and the outside will have a coat of epoxy and be finished with U-POL Raptor. ![]() Click image to enlarge ![]() Click image to enlarge Not the final fit as it will be in and out a few times yet, but a it seems a solid base to build on. ![]() Click image to enlarge Some of the old Sankey tub bolt down points were in the perfect location. ![]() Click image to enlarge Couldn’t wait to see if my measurements of the water tanks were correct... so a quick test fit. ![]() Click image to enlarge ![]() Click image to enlarge Spot on ![]() |
