Home > Puma (Tdci) > Exhaust Mid Box |
keef9t Member Since: 13 Mar 2016 Location: manchester Posts: 170 |
The exhaust mid section (standard mild steel) is off while I remove the transfer box. It's not in good condition so I am considering replacing it. Does anyone know of an "off the shelf" straight through section in mild steel.
Sorry, should have mentioned it's a Tdci 2.4 90 H/T Last edited by keef9t on 19th Aug 2019 7:28pm. Edited 1 time in total |
19th Aug 2019 4:52pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
Personally wouldnt bother the drone of removing it will put your head away in the long term
19th Aug 2019 5:45pm |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
I wouldn't say it's much louder at all without the midbox. Certainly not a drone, but maybe my tyres hide the noise.
https://www.ebay.co.uk/itm/LAND-ROVER-DEFE...SwHrlcJe9z |
19th Aug 2019 6:14pm |
Each to their own, i had one on my old tuned td5 and took it back off, couldn't take the noise on the long journeys.....whered i put my pipe and slippers
19th Aug 2019 6:27pm |
Ah, that might be a TDCI vs TD5 thing.
19th Aug 2019 6:53pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3674 |
Just given one away!! I had the straight through pipe and it makes no difference to the noise at all. The dpf does that for you.
19th Aug 2019 7:02pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5692 |
90 yes a difference 110 no difference Td5 or Tdci that’s my experience.
19th Aug 2019 7:48pm |
That'll not be all tdcis though. |
19th Aug 2019 8:07pm |
Am I right in thinking that the 2.4's didn't have a DPF, only the 2.2's?
19th Aug 2019 9:38pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
No DPF on a 2.4 Ive done it on mine worth doing just to save the weight. At idle it has a nice deeper tone , above idle no noticeable difference in noise. I brought terrafirma but it was a mare to fit as the angles at the end were all wrong and I had to cut off and reweld the hangers buy a better make DEFENDER 90 TDCI XS,
20th Aug 2019 5:28am |
Thanks for your comments.
Has anyone bought one that fits without having to modify to fit. |
20th Aug 2019 7:25pm |
The cheap SS one from paddock fits just fine. Don’t forget gaskets as well; 2 bolt for one end, 3 bolt for the other.
21st Aug 2019 5:14am |
