Home > Td5 > Oil leak |
spam242 Member Since: 06 Aug 2016 Location: west sussex Posts: 73 |
As a complete TD5 newbie, im not really sure of the severity of this oil leak but it seams to be from every orifice. It’s a 2006 model with 110,000 miles on the clock.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge I’ve attached some photos but could someone kindly point out how bad this could potentially be and what I can do about rectifying it. |
9th Aug 2019 12:12pm |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
First things first don't worry too much about it. They all seem to leak.
Is it dripping a lot of oil onto the drive? If so just keep an eye on your dipstick until its fixed. You need to find the highest point on the engine it is leaking from. I'd suggest an engine steam clean and then take it for a run so you can see where it is actually leakign from. Oil can be blown a fair old distance backwards from driving. Once you know where it is leakign from you can figure out next steps. Alternativly take it to you your local friendly garage and ask them. |
9th Aug 2019 12:35pm |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
Looks similar to mine.
I have no drips onto the drive and the oil level is always good. The only problem I have is when it comes round to MOT and I get the advisory "Oil leak". I wish they would tell me where from so I could do something about it |
9th Aug 2019 1:43pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5849 |
A jet wash before the MOT helps 1999 Defender TD5 110
9th Aug 2019 1:59pm |
Thanks for the reply’s, I should have mentioned that I’ve not yet bought it. It’s one I’m thinking of purchasing so unfortunately the Ideas of cleaning it then checking after are not possible. I will however check the highest point of the leak. It has been on the drive for 3 weeks and there is an oil stain underneath so I do know it’s actively leaking. My main concern was that the mot advisories said, ‘oil seepage’ and ‘oil on minimum level’
9th Aug 2019 2:10pm |
130dreamer Member Since: 29 Feb 2008 Location: Romford Posts: 100 |
That could be a photo of my old 2003 TD5 130!
The leak on mine turned out to be the sump gasket. Easy job to do and not expensive at all. Cleaning the drive on the other hand...... |
9th Aug 2019 2:12pm |
Advantage of a leak is it does wonders stopping corrosion. My logic
when buying was I could easily fix an oil leak but corrosion once there is permanent |
9th Aug 2019 3:09pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1627 |
Probably piddling out of the cam seals, wouldn’t worry too much looks like every Td5
9th Aug 2019 4:21pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Contrary to most of the replies here, Td5 engines shouldn't leak. Mine has 136k miles on it and is bone dry. I would remove the acoustic cover from the top. Get some Gunk engine degreaser and then steam clean ideally (or jet wash) the engine avoiding seals and sensors.
It will then be much easier to identify the point(s) of oil egress. Most of the common leak points are easily remedied 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
9th Aug 2019 4:59pm |
Must be no oil in yours then Grafty
9th Aug 2019 5:01pm |
There was last time I checked 2002 90 Td5 Station Wagon
9th Aug 2019 7:52pm |
So providing it’s not something catastrophic what sort of money do you think I’ll be looking at to rectify or at least slow down the leak?
11th Aug 2019 3:42pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
If you can do it yourself and you probably can, it will not cost much except a lot off time. Seals and gaskets are cheap but if somebody else has to do it labour is expensive. I think you will spend less the 100 pound on gaskets. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
11th Aug 2019 4:53pm |
Thanks for all the help guys, with that knowledge under my belt i was going to put an offer in but have just found out it was sold yesterday. Never mind, at least i know what to look for on the next one
12th Aug 2019 8:33am |
