Home > Puma (Tdci) > Creaky (not squeaky) clutch pedal...
agentmulder
Kuwait
Hello all,
So my clutch pedal has become more and more creakier over the last 6 months, I'm 99% sure it isn't the spring as I've lubricated the nuts off the damn thing and can see its action is smooth, aside from that the sound some from higher up - have a look/listen for yourself:
It happens more often on the return stroke and usually when you're doing more delicate clutching around the bite point. Kind of feels maybe like it's binding and releasing very fast.
I've torqued the pedal box screws, lightly tweaked the lever/linkage with small pry bar, tapped all with hammer the 'Fonz' style, lubricated all the other linkages and shafts I can see from the top side, including following the advice to get the lube inside via a grease nipple here: http://www.defender2.net/forum/post263911.html
Clutch, clutch master and slave were replaced about 1.5 years ago. The master was a genuine part.
Still, it creaks (not squeaks).
Is this the same sound others are talking about in all the other threads? Pushing the pedal by hand I can feel the creak too. Solved the bowel problem, working on the consonants...
Post #661078 1st Nov 2017 5:39am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
I did the same investigative work on my clutch, trying to find and slay the creak/squeak.
In my case it turned out to be two areas - the first was the push rod into the master cylinder (behind the rubber boot). I found a spray grease could be aimed at that spot. That was just a slight squeak though.
However the grease nipple trick helped the most - but not immediately - to solve the creak just like your sound. What I found was the grease injected tended to stay near the grease nipple end of the shaft and it still creaked. If you injected more grease it just squeezed out on one side only.
I solved it in the end by using a slim pry bar to force the fork over and close off it's escape route nearest the grease nipple. Once I had grease appearing at both ends of the shaft the creaking stopped. Every few months I give it one squirt of the grease gun and so far after two years or so the clutch pedal is still quiet. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #661084 1st Nov 2017 7:11am
agentmulder
Kuwait
Quote:
But not immediately
OK, there's still hope!
I'll have another crack at the nipple tactic - try to see where it's ending up ... Solved the bowel problem, working on the consonants...
Post #661086 1st Nov 2017 7:16am
nosnibod
In my case loads of grease ended up in the footwell at first so be prepared Rolling Eyes Dave
Post #661088 1st Nov 2017 7:18am
dorsetsmith
clutch pedal box overhaul or replacement, the clutch pedal pivot pin/shaft in pedal box are worn-out i.e. the hole at top of the clutch pedal are not round but slotted, had to overhaul one the only way i find to sort the problem remove the box and strip it down rework the pivot pin/shaft and holes with new metal and drill out. the box had been in defender for 120.00 miles work
Post #661095 1st Nov 2017 8:48am
agentmulder
Kuwait
Slotted? Yikes Neutral
Pedal box out sure is a pain... Weld in material then mill it out? And the bleed too Big Cry
Mind you, I'm more mechanically tricked up than the last time I did the job so maybe it wouldn't be so bad.
Hopefully the grease will kill it (job for two days from now) Solved the bowel problem, working on the consonants...
Post #661303 1st Nov 2017 11:08pm
Zed
I just turn the stereo up.
Post #661304 1st Nov 2017 11:12pm
agentmulder
Kuwait
Ugh, so no amount of grease in the joints appears to remedy this creak...
Any more ideas before I remove the box and strip it? Solved the bowel problem, working on the consonants...
Post #662330 7th Nov 2017 4:52am
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
That's exactly what I do!! Rolling with laughter ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #662972 10th Nov 2017 12:35am
El Rey
Australia
I put in the grease nipple and the grease and for 2-3 months it worked well.
Then the other day there was some big globs of grease in the footwell that squeezed through, and within a day or two of that the squeak/croak was back.
Don't really want to deal with grease inside the footwell like that regularly so will have a think before pumping any more in.
Post #785815 9th Aug 2019 4:09am
agentmulder
Kuwait
Ended up nuking this one with a new pedal box, replaced master cyl as well - may as well get it done ahead of schedule Rolling Eyes Laughing Solved the bowel problem, working on the consonants...
Post #785853 9th Aug 2019 1:18pm
El Rey
Australia
Mine is only MY2016 so replacing the pedal box and master cylinder would make me sad.
Post #785854 9th Aug 2019 1:20pm
Caterham
that's why LR started fitting sub woofers etc.
it proved easier, cheaper and reduced warranty claims than trying to fix all the other issues Rolling with laughter
Post #785878 9th Aug 2019 2:55pm
