Home > Technical > Indicators not working, Hazards do... |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
Does anybody have any suggestions at all? 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
9th Aug 2019 9:16am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Is the basic loom on the Wolf the same as a 300tdi one or totally different?
Steve 02' 110 TD5 Double Cab Rebuild Thread |
9th Aug 2019 9:35am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6633 |
Is the hazard switch supplied with and (in the off position) giving out the 12V ignition feed for the indicators? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
9th Aug 2019 11:00am |
Click image to enlarge 1988 90 Td5 NAS soft top 2015 D90 XS SW |
OK the Wolf is slightly different than a standard 300 Tdi, but the principle above applies at the moment.
Do you have an ignition switched supply at pin 8 of the hazard switch (GREEN above, GREEN/YELLOW on a Wolf)? This is supplied from Fuse 4 on a Wolf, the supply to Fuse 4 is from a ignition controlled relay. With the switch off (Hazards off), is this 12V ignition supply then present on the LIGHT GREEN wire (pin 5) of the switch plug? This is the supply to the flasher relay with the hazards off. As the hazards work the 6/7 way lighting switch must be in the correct position, the hazard permanent and feed to the indicator ignition relay (mentioned above) are supplied from the same output circuit from that switch. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
9th Aug 2019 11:19am |
Thanks Martin, don't forget though, it's all 24V
I waggled the hazard switch and they worked. There's a Wolf and Tithonus FaceBook group who suggested that when the hazard switch is dying, it can cause this fault so a new one is in the post. Thanks for the details, I shall squirrel that away. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
9th Aug 2019 5:02pm |
OK replace "12" in my post for "24". Still applies 1988 90 Td5 NAS soft top
2015 D90 XS SW |
9th Aug 2019 5:11pm |
Gaz M Member Since: 14 Apr 2023 Location: Bucks Posts: 6 |
Further to this thread I’ve got same issues . Out of the blue no indicators on stalk horn /flash ok. Hazard worked at that point . Then indicators started again . Next time out nothing. So new flasher relay . New switch . Nothing . I’ve metered purple live and green ign live feed to switch all good . Power to flasher relay . Fuses ok .only thing I haven’t changed is stalk , would that be it , what could go awry in there I’ve power everywhere I should have and running out of ideas ! ? Bloody typical been fine all year MoT looming then gremlins !🙄 I’d been in behind dash as wired up few dials and put heated screen in etc but everything worked before I re fitted binnacle .
Anyone help ? Cheers |
21st Apr 2023 12:34pm |
Yes, it'll be the stalk. The innards get hot as they carry the load for the headlights, which softens the plastic and the contacts move out of position. They sometimes move back again, so miraculously everything works again for a while. The immediate solution is a new switch and the longer term one is to introduce relays into the headlight circuits so that the switch doesn't carry their full load. Darren
21st Apr 2023 12:45pm |
Ok. Cheers Darren are they same part as civi defenders ? Or specific to TUM
21st Apr 2023 1:10pm |
Ah, that I don't know, I'm afraid. Darren
21st Apr 2023 1:44pm |
