Home > Maintenance & Modifications > Swivel kits
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Swivel kits
Hi chaps, the time has come for me to replace the swivels on my 90, not having done this job before has anyone got any advice on the best kit to purchase , I would like to avoid britpart 😬
Many thanks
Mike Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #783984 30th Jul 2019 8:49am
Grenadier
https://bearmach.com/swivel-housing-kit-bk-0159 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #783994 30th Jul 2019 9:40am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
If you order the Britpart kit that has a G at the end of the serial number it is OEM manufacturers in a blue box ie Timken bearings and Corteco seals. I would avoid the normal Britpart ones though. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #783998 30th Jul 2019 9:49am
Interesting that that kit does not appear to include the top pin (at least there isn't one shown in the illustration).
Post #784010 30th Jul 2019 10:59am
dorsetsmith
top pin FTC2882
bottom pin FRC2894
and two 606666
for set up shown
Post #784029 30th Jul 2019 12:42pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
this ^ Thumbs Up
Post #784035 30th Jul 2019 1:03pm
taffrican
Thanks chaps, I took the advice offered and went for the “g” marked britpart kit as it was listed as Oem, a little bit more expensive but that is of no concern, it looks like a nasty job so don’t want to be doing it over because I wanted to save a few pennies..... but the original LR prices are scary, you’d be looking at almost a couple of grand to do both swivels and new wheel bearings, I wonder how many people actually take their defender to LR to get their swivels done Shocked Optimists say the glass is half full..
Post #784340 1st Aug 2019 10:15am
DS, a very useful post, thank you. It is of course the lower pin which appears not to be included in the bearmach kit.
For those who don't know, the top pin changed from 2007 and integrated the inner race of the upper bearing into the pin, the rollers being held in a plastic cage and free from the pin. Generally the post 2007 arrangement seems to be inferior in every respect, especially since it has fewer rollers. As far as I know, the <2006>=2007 vehicle without problems and is probably a sensible upgrade.
The later type pin TAR100040 can be seen in the illustration here:-
https://rimmerbros.com/Item--i-TAR100040
Post #784345 1st Aug 2019 10:38am
taffrican
So why is there no top pin in the kits, I looked at a few when looking at which kit to buy and I don’t recall seeing any, should I order separately or do they rarely require changing? Seems strange not being part of the kit Shocked Optimists say the glass is half full..
Post #784347 1st Aug 2019 10:49am
The Bearmach kit includes the top pin and bearing (as stated in my second post I mistook the top pin in the picture for a bottom pin) but not the bottom pin and bearing. I imagine that the bottom pin is considered not to wear as quickly, although it is hard to see why this should be.
I was rather shocked at the prices of the bottom pin. Rimmer Bros (link in my last post) list a genuine lower pin at ÂŁ92.22, but a pattern part at ÂŁ2.94. Shocked That means that the genuine part is over thirty-one times the price of a visually identical pattern part!
Post #784348 1st Aug 2019 11:01am
taffrican
If you look at LR prices for the swivels it is nearly ÂŁ700 just for the housing never mind the rest, scary prices, but yes, there must be a valid reading why the bottom pin isn’t included and I can only imagine it would be less wear 😊 Optimists say the glass is half full..
Post #784353 1st Aug 2019 11:13am
dorsetsmith
More top pins
Left hand side Railko bush top pin none ABS FRC3511 right hand side TAR 100040 none ABS or TAR100050 ABS
Left hand side Railko bush none abs 8510267 right hand side thrust washer for the Railko bush none ABS FRC2906
bottom pin stay the same
bottom pin FRC2894 and 606666
all be pends on the age for your axle and land rover, swivels ball also changes dependent on the set up
Post #784356 1st Aug 2019 11:39am
mynamesbuck
United Kingdom 2014 Defender 110 Puma 2.2 USW Loire Blue
Excellent advice cheers guys
Post #784931 4th Aug 2019 10:30pm
NickMc
Used to not include the pin because it was genuine only and it’s a separate bearing so you reuse the pin if not damaged (imagine it like a stub axle your wheel bearings ride on if that makes sense?) - they changed it again and like blackwolf says they’re just Confused
Older railko bushes take the thick seal and newer take the “thin” seal. Don’t forget the seal retaining ring when you put it together and make sure the bolt holes line up first too (won’t fit backwards)
Post #785038 5th Aug 2019 5:23pm
