Home > Maintenance & Modifications > Windscreen seal
mini Anaconda
Windscreen seal
I need to replace my windscreen seal and looking for recommendations for a replacement seal, or are they all pretty much the same as each other? Can't afford to pay £100 for a genuine one.
Thanks. BORG - Bucks & Oxon 4x4 Response Group
Post #783596 28th Jul 2019 1:27pm
Ask your mearest 'one man band' windscreen company to get you a price (ie not Autoglass). Thumbs Up
Post #783792 29th Jul 2019 2:40pm
Bluest
I've got a genuine one waiting to go in, but there were some positive comments for the Bearmach one when I was doing my research. 2007 110 TDCi Station Wagon XS
Post #783793 29th Jul 2019 2:45pm
MartinK
I think I would risk non-genuine. Search for part # cpe500020 - plenty available for under a tenner!
Use plenty of sealant (sikaflex?)...
That's what I would do anyway!
Agree the ~£90 for an OEM part is a bit steep to say the least! You could always try Dan @ Duckworth's first? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #783795 29th Jul 2019 2:52pm
gilarion
I would opt for the cheapest aftermarket, reason being is having fitted genuine a few times and to my cost found they last no longer than aftermarket, in fact, they may even last not as long. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #783798 29th Jul 2019 2:55pm
There was a time when the genuine ones were definitely superior, and had more sealing ribs than the aftermarket ones. Now the genuine ones have been value-engineered to the extent that they are just as inadequate as the cheap ones, albeit still at the inflated OE price.
An aftermarket one properly fitted with an appropriate sealant should be fine.
I would not use Sikaflex on a windscreen seal since it is likely that one day you'll have to replace the screen and you don't really want to find that the seal is now irremovably bonded to the frame. I would just get my local friendly independent windscreen fitter to fit it using his expertise and recommended sealer, on the understanding that if it leaks he'll get it back for another attempt at his expense.
Post #783818 29th Jul 2019 4:50pm
Bluest
Frost Restoration do a non adhesive windscreen sealant, it was recommended on here by Zagato I think. 2007 110 TDCi Station Wagon XS
Post #783821 29th Jul 2019 5:05pm
CarMan
I bought an AllMakes PR2 OE seal for £11.45 posted three and a half years ago and it's still like new. Had a local one man fitter install it on the drive which wasn't cheap, or easy, but has been fine ever since Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #783829 29th Jul 2019 5:37pm
mini Anaconda
Thank you for the replies.
I am going to give it a go sealing the original seal first which looks in good condition, although it has started pouring in recently.
This is the stuff I am going to use as its more of a sealer than a bonding glue, https://www.dortechdirect.co.uk/arbomast-a...eens.html/
If that doesn't work then I will get a new seal and give it a go fitting it. BORG - Bucks & Oxon 4x4 Response Group
Post #783854 29th Jul 2019 7:15pm
miker
Bought one recently, with a replacement screen. Believe it was a bearmach. Didn't use sealant as there wasn't any on what came out, and the frame was in good condition, just thoroughly cleaned it all!
No leaks thus far....
Post #783988 30th Jul 2019 10:03am
It shouldn't be necessary to use any sealant if the seal and aperture are in good condition. The need for sealant is usually indicative of deterioration.
Post #784012 30th Jul 2019 12:00pm
McGeordie
United Kingdom 2014 Defender 110 Puma 2.2 USW Montalcino Red
Just done mine, bought a genuine screen rubber, my local indie body shop fitted for 60 quid, he does glass removal/replacement himself, say the rubber was a really good fit, I know the OE rubber is much more expensive, but hoped it would be better quality and fit. Sold Def 90 HT 2010...Stornaway..(SOLD in Oct 2014)
Current: delivered October 2014:- 110 USW XS.....Montalcino Red
Post #784014 30th Jul 2019 12:06pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
Felt like saying this myself, but you said it for me. Spot on.
Post #784039 30th Jul 2019 2:06pm
mini Anaconda
I understand that originally they are fitted without sealant but the Land Rover water ingress instructions suggest that sealant is the recommended solution.
For a couple of pounds for the sealant its worth giving it a go first rather than risk breaking the screen changing the seal. If it doesn't work then I haven't lost anything and if it does work then I have potentially save a decent amount of money.
I shall let you all know how I get on. BORG - Bucks & Oxon 4x4 Response Group
Post #784057 30th Jul 2019 4:03pm
