Home > Technical > Tow ball -lowering
Banbury
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
Tow ball -lowering
Hi Folks,
I’ve done some searching on this topic and want to confirm I am ordering the right parts
Problem: At its lowest setting the tow ball is too high relative to the trailer (Brian James Race Transporter 4).
Solution (?): Buy this kit, made by Dixon Bate’s, which allows lower tow ball.
TOW KIT ADJ - 90/110
Part Number DA2121.C8
Weight (+ vol) 18.00 kg
Brand: DIXON BATE
Supplier: BRITPART
If someone could confirm/ deny I have it right? Also if you have a decent supplier then that would be appreciated.
For completeness here are a couple of photos of existing tow bar set up.
Many thanks 👍
Post #783780 29th Jul 2019 1:20pm
Retroanaconda
Yes - but you need to buy the correct version as the brackets on your 2015 90 are different to the pre-1998 ones which that linked one is designed to fit.
You need this one:
https://dixon-bate.co.uk/products/gb/land-...coup-.html
Post #783787 29th Jul 2019 2:11pm
MartinK
Or.... do what I did and lower the rear suspension. My trailer sits level now, and I have a much better on-road ride, without much deterioration in off-road capability...
https://www.defender2.net/forum/topic49065...oilsprings Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #783791 29th Jul 2019 2:31pm
Banbury
You need this one:
Good catch... Did not consider Model Year.
I think this is the right part LR007221.
Note: told by Brit-Part it is out of stock.🙄
Many thanks.
Post #783807 29th Jul 2019 3:56pm
Banbury
MartinK wrote:
Or.... do what I did and lower the rear suspension. My trailer sits level now, and I have a much better on-road ride, without much deterioration in off-road capability...https://www.defender2.net/forum/topic49065.html?highlight=coilsprings
Never thought on doing that. I’ll go and look at the ‘90 and see how she sits.🤞
Post #783808 29th Jul 2019 4:01pm
