Home > Maintenance & Modifications > Difficult to fill tank
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
I had the breather/vent hose replaced on my Td5 90 on Friday. When filling up, the pump at the station keeps clicking off. So trying to fill up with diesel takes an age. I’m guessing that this is happening because air isn’t going up the breather/vent hose? I’ve used 3/4” - 19mm marine fuel line. Any ideas as to why this is happening with the new hose? My thinking is to buy an extra piece of marine line to extend the hose and put a bit of a bend in it to relieve any choke/tight points in the hose. Any ideas and advice would be greatly appreciated! Thanks! Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #783600 28th Jul 2019 12:37pm
miker
Tried a different pump/station? I find some pumps are really twitchy and click off when filling the Defender. Different angle usually does it, or pulling out slightly.
(Stop sniggering you lot)
Post #783673 28th Jul 2019 7:57pm
Sulisuli
Story of my life miker, pull out and try a different angle Rolling with laughter Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #783681 28th Jul 2019 8:13pm
Rashers
Rolling with laughter Rolling with laughter Rolling with laughter
Between the sniggering, I would try a different filling station if possible. I find the Defender fills better if I just pull the nozzle out a little. Saying all that, I have to listen for the tank to fill. It changes tone as it gets full and if I forget it usually spits diesel all over the forecourt and me if I am unlucky.
Post #783690 28th Jul 2019 8:42pm
BaronDefenders
I’m glad I’m not the only one then! I’ve had it before and pulling out slightly or changing angle helped. Now I have to pull out and slow down the flow rate Laughing I’ve only been using supermarket filling stations since the vent hose replacement so I’ll try somewhere like a BP next time! Charlie
2002 Td5 90 (SOLD)
Post #783726 29th Jul 2019 7:05am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
The trigger on the end of the pump start to wear and cannot hold the spring mech back so they click off for this reason.
It happens with my local garage, just try another pump next time. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #783729 29th Jul 2019 7:37am
Rashers
Not with the Defender, but my last Ford Focus company car (62 Plate) was an absolute nightmare when our local Sainsbury's installed new pumps. It was so bad, I tried to fill up at another Sainsbury's (I was, at the time collecting Nectar points).
There is obviously something they can do to remedy this problem as others were moaning and after about six weeks, the pumps were fine.
Post #783733 29th Jul 2019 7:49am
hank
Slightly off topic, I recently used a HGV pump Shocked wow that thing filled the tank in seconds! > 110 XS Double Cab
Post #783736 29th Jul 2019 8:25am
BaronDefenders
OK seems like it’s down to dodgy pumps then! Thanks for the assistance chaps! I’ll try a non-supermarket station tomorrow and report back! Charlie
2002 Td5 90 (SOLD)
Post #783799 29th Jul 2019 2:02pm
BaronDefenders
Solved the problem the other day! Turned out that the new vent hose had rather a significant kink in it. Just pulled it straight and all is fine now! Charlie
2002 Td5 90 (SOLD)
Post #784675 3rd Aug 2019 3:14pm
