Home > Puma (Tdci) > 2016 Puma - problems with 1st and 2nd gears AFTER service
Page 3 of 3 <123
El Rey
Australia
Iktank wrote:
El Rey wrote:
@Iktank Can I ask what overfilling does and what symptoms it exhibits?
Sorry not been on here working away.
Overfilling will cause difficulty in changing gears, even cause overheating as the oil does not have enough space to move around.
Common issue with the gearbox being overfilled, it does not have a level hole just a filling hole so correct amount must be put in - off the cuff I think it is 2.2ltrs.
I had a whining from my box as it was overfilled by LR
Cheers for getting back about this. They changed the oil a second time when I took it back due to the gear change issue. As I mentioned in another post, basically all these guys do is work on Defenders, Series and Rovers, so I assumed they would be on the ball with this kind of thing. But I will ask when I take it back for some work in the next month or so.
Post #782846 24th Jul 2019 10:18am
El Rey
Australia
spudfan wrote:
The gearbox takes GL4 spec. If GL5 spec was used it will react in a bad way with your gearbox innards.
Cheers again. They use Valvoline Duragear 75/85 gl4
Post #782847 24th Jul 2019 10:18am
Page 3 of 3 <123
