Home > Puma (Tdci) > Random issue with my Defender...
Eduardo
Hi there
From some time ago my Defender are experiencing a random issue that still I cannot locate Sad
Some times, randomnly, the engine lost power and is not possible to run over 60 KPH.
No engine ligth and not DTC code stored (using a normal scanner) and no strange sound or anything that guide me to the culprit.
If I stop the car and wait some time, star to working normal again.
Appears that the turbo refuse to work but I'm not sure (no special sound when the failure happens or when working OK)
I already check visually the wiring loom to see if have some wire broken.
Any Thoughts from where I can start?
Cheers! Eduardo
Post #782674 22nd Jul 2019 10:35pm
Have you cleaned your MAF and MAP sensor, in particular the latter?
I would also check the turbo actuator is working correctly also as a few starting points.
Thumbs Up Chillin In The Backwoods🇬🇧🇺🇸
Post #782675 22nd Jul 2019 11:15pm
hank
Have a read of this https://www.defender2.net/forum/topic62985.html
And check actuator movement is free
 > 110 XS Double Cab
Post #782679 23rd Jul 2019 4:44am
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
Mine derates when the temp gets over 110 deg C
Gauge on dash still shows normal temp but OBD2 plug in gauge tells different story.
Mark
Post #782701 23rd Jul 2019 9:51am
Eduardo
Thanks to all!
Now the Defender is in the farm not with me).
So, as soon arrives I will check it.
Cheers! Eduardo
Post #782884 24th Jul 2019 12:49pm
Eduardo
Well
A pending DTC appeared: PO234 (Turbocharget overboost), so probably hank is right.
Anyway, I will ask to my wife if she can clean the MAF and the MAP sensors (not easy task)
Update: the code dissapeared after run again the car at 100 kph... Eduardo
Post #783151 25th Jul 2019 8:53pm
Eduardo
Finally 2 issues Sad
a) Turbo actuator are not working properly.
According to my Indy is better to change the whole turbo. He had problems in the past to pair the turbo with a new actuator he
said that the actuator stroke of the spares offered are not the same than the turbo request.
b) The bracket bearing (where the viscous fan is sitting) have a lot of play and must be changed
In Chile both pieces available but at a cost that almost double the price of import from UK.
So...
Waiting the final quotation from Dan @ Duckworth to put the order
Cheer to all and thanks for the help Eduardo
Post #787779 19th Aug 2019 8:10pm
MMR1988
Germany 2008 Defender 110 Puma 2.4 SW Alaska White
Check the wire next to the connector of the turbo actuator. I had the same fault (Turbo overboost) and one of the wires were just broken just within the connector. Not directly visible, you need to slightly twitch each wire to get it visible.
Problem was, that the wire disconnected on road bumps and the engine runs only 3000 RPM with additional lower power with this fault. After the engine restart, the wire was connected again until I hit the next bump.
Best regards
Max
Post #788410 23rd Aug 2019 7:58pm
