![]() | Home > Tdi > Crankshaft woes |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
As ever though, if you rebuild your own engine. You know what you have.
Whereas with another engine, apart from it being at least 21 years old, you have no idea what sort of knuckle dragging gorilla has worked on it. Similarly, if it is that good an engine, why isn't it in a vehicle? It is not a Defender, it is a One_Ten |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
Yes that was a thought, however it is in a disco with a rotted out chassis so genuine reason for its being, I also know the owner and where he lives
![]() ![]() 1994 Def 90 300tdi |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
pretty common fault on them, quick fix bush trick is brass key in and weld it up- remove brass key and bingo
