Home > Off Topic > Recommend Mail Order Steel Laser/Water Cutting Company |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2300 |
I am looking to get a a single item cut from around 3mm mild steel. The piece fits within 200mm square
I have googled and contacted precision-profiles and laserprocess but neither replied. Guess a single small piece is not worth their time, so looking for recommendations from experience of such work? I intend to provide a cad file > 110 XS Double Cab |
17th Jul 2019 12:28pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
I believe there are some ebay sellers advertising the service if you send them a .dwg/.dxf file of the part. We had some stuff waterjet cut for the rollcage mounting brackets and it was hard to find a company who were willing to do a single item for cash payment. They are all set up for larger orders on account.
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
17th Jul 2019 12:30pm |
Magic I will take a look > 110 XS Double Cab
Ooooh Will PM > 110 XS Double Cab
17th Jul 2019 12:50pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4209 |
If AJC can’t help, I would suggest finding your nearest place and walking in off the street. I worked for a profiling firm with two big lasers, and small jobs like that are not worth messing about with, but if you walk in with a good CAD file and some cash you will likely to get someone who will help you out. 2007 110 TDCi Station Wagon XS
17th Jul 2019 1:10pm |
Yeah I get where you're coming from but I'm away working in the Middle East and wanted the part ready when I visit home for annual leave > 110 XS Double Cab
17th Jul 2019 2:14pm |
rallysteve, my ebay skills have let me down here. Would you share the listing you used? > 110 XS Double Cab
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2154 |
i found a couple of listings with the search "water jet cutting" - probably others
https://www.ebay.co.uk/itm/Waterjet-Cuttin...SwMvdc~5ok https://www.ebay.co.uk/itm/Aluminium-Water...SwnAddFe6I |
17th Jul 2019 3:12pm |
Yeah found them. One is stainless and the other aluminium but I’m after mild steel > 110 XS Double Cab
17th Jul 2019 3:21pm |
I used a local company through a work connection in the end but had to go through setting up a dummy account etc.
http://www.controlwaterjet.co.uk/ in case you want to try them. There are a few if you have a dig through the listings. I have found a few through 'plasma cutting service' and 'laser cutting service' as search phrases. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
17th Jul 2019 3:29pm |
