Home > Puma (Tdci) > Central locking & electric windows
110UTEGP
South Africa 2016 Defender 110 Puma 2.2 USW Montalcino Red
Good evening,
I have recently purchased a new 110 utility, the vehicle doesn't have factory fitted central locking or electric windows. It has a standard lock/unlock remote that activates and deactivates the alarm.
Is it possible to fit central locking & electric windows ?
thank you...........
Post #525573 20th Apr 2016 6:25pm
ParabolicSwivel
Hi
I'm also in the process of fitting central locking. Doesn't look like big a challenge except maybe fiddling with the alarm system since the version I have doesn't have the necessary relays fitted. For now I'm going to leave it working independently of the alarm.
There is a ton of info in the forum archives - try a search and you'll come up with great stuff like this:
http://la7dja.org/defender/cdl/
No idea about the Windows though.
TTFN
Post #525769 21st Apr 2016 3:41pm
110UTEGP
Hi.
Got windows sorted.....wiring harnesses for the windows and central locking are already factory fitted (Found them hidden in "A" post, plugged in door harness and windows work fine Thumbs Up
Land Rover have said I need to swop out control module behind dash to get central locking working........
Cheers !
Post #525794 21st Apr 2016 6:23pm
Cupboard
technically they're right, but people have had a lot of success just attaching the missing relays.
The unit is the same with or without central locking, it's just whether the central locking bit is actually there. It's not hard to add by all accounts.
Post #525803 21st Apr 2016 7:32pm
110UTEGP
Thanks for the heads up, any idea where relays are located ?
Post #525877 22nd Apr 2016 6:49am
Martin
Site Admin
The missing relay is inside the green 10AS unit, I've just upgraded the one in my soft top 90.
However a 2016 Defender has the newer alarm system so I don't know whether these are similarly upgradable  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #525880 22nd Apr 2016 7:19am
110UTEGP
Thanks........the quest continues !
Post #526083 22nd Apr 2016 9:08pm
Cupboard
Ah, I hadn't realised that Embarassed
When did they change and what do they use now?
Post #526096 22nd Apr 2016 10:17pm
Simon.pl
Poland 2007 Defender 110 Puma 2.4 HT Keswick Green
Sorry for resurrecting an old thread, but I don't want to create a new one.
If I have the relay inside the 10AS unit, does it mean that the Central Locking should work after attaching actuators to the wires that ends just at the entrance to the front door?
I've been installing aftermarket central locking system and want to use factory wires.
Just made a short test with the fob and the only thing I get is horn that goes on once, but that is ok as there are no door switches installed yet.
Should the actuator work even knowing that the doors are not closed, or all doors must be closed to acitivate the central locking?
Mine is MY2007 110HT
Thumbs Up
Post #687094 16th Feb 2018 10:38pm
nitram17
Just a question....I have a my2015 90 ....is it a simole job to add another extra actuator to the original setuip..do you just piggy back onto one of the door actuators ...or is it more complicated!
Post #687098 16th Feb 2018 10:43pm
Simon.pl
How did you upgrade the unit? By adding external relay, or there can be one soldered inside?
Post #687107 16th Feb 2018 11:11pm
dorsetsmith
Post #687127 17th Feb 2018 7:16am
Simon.pl
Cheers Dorsetsmith
Wish I new about this page before I reinstalled my unit and dash back in Confused
Had everything in pieces for almost a year!
Well - need to check precisely what part no my unit is. There is NEC relay inside, but have no idea what "associated components" mean.. And at the end it may appear that it was not programmed to have CL active Crying or Very sad
Post #687171 17th Feb 2018 11:13am
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
dorsetsmith wrote:
have a look at the link below
https://www.technozen-electronics.co.uk/la...-services/
Seems the black 10AS modules are not that easy to add central lock to.
I also found this out the hard way. May need to go to the dealership for insight on how to program and install the wires...
I have the 5wire actuator on the front doors and 2wire on the rear, so from the keyhole i can lock and unlock the doors. However, a more luxurious install is using the remote.
Post #781865 17th Jul 2019 12:50pm
24heuer
Scotland 2010 Defender 110 Puma 2.4 CSW Keswick Green
C/L parts list
Hi,
I'm going to have a go at retrofitting genuine central locking to the front doors of my '09 110 as it looks like I have the connectors hanging loose in the A-pillars already.
I'm just trying to price it and putting together a parts list I have the following -
looks fairly simple - wiring, actuator, link rod and clips either end?
Drivers door
FUD500020 Actuator & switch assembly-central door locking driver's door
CWH000010 Clip-linkage
FQK500040 Link rod Latch to actuator
IPN500250 Clip-linkage Latch to actuator
LR016315 WIRING HARNESS FRONT DOOR WITH ELECTRIC WINDOWS - DEFENDER 2007 ON
Passenger door
FUD500030 Actuator & switch assembly-central door locking passenger’s
LR016316 WIRING ASSY FRONT DOOR PASSENGER DEFENDER
Sorry to ask -
Is there anything else I need?
I haven't removed the door cards yet - I'm guessing I should already have these holes pre-drilled in the door casing?
I understand that as per the technozen page I'll likely need to get the 10AS modified also as it has reference YWC50066 on it.
Many thanks, Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #785475 7th Aug 2019 12:58pm
