- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Lorryman100
I did find on mine with the original fuel map a certain amount of throttle latency when taking my foot off the accelerator. Let me explain, driving down the road and I remove my foot from throttle expecting the engine to start braking the landy but instead it continues to drive as if my foot is on the pedal for about 2-3 seconds before the revs drop and the engine starts braking. After this I was aware of instances when changing gear of the revs not dropping when my foot was removed from the throttle, again if I held the clutch in it would go on for a second or two before dropping. This gave me cause for concern a couple of times when I wanted to stop quickly as the landy seemed to want to drive on. Needless to say this has now been sorted and the revs drop immediately when the foot comes off the throttle
28th Jun 2011 12:12pm |
Lorryman100
It was the original map file that caused it. Since remapping the latency has been resolved by Gary at Alive tuning
28th Jun 2011 12:30pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
