![]() | Home > Puma (Tdci) > Surging |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
Am I just imagining things, or does my 110 sometimes drive as though I am lifting my foot on and off the gas pedal? Its very slight, but noticeable enough, even the mrs noticed it today, seems to only happen at low speeds. Its done this maybe 2 or 3 times now. Has anyone else experienced this? Rev counter is not moving (ie its not bouncing up and down) so I don't think the engine is literally revving up or anything, just feels as though its pulling, then stops, then pulls again...we ignore the speedo as its stuffed due to the tachograph.
Or is it just me? ![]() 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
sounds like anti-stall ... pre-programmed
Oh right, why is that kicking in then when I'm driving along? 2011 110 USW
Landie Boy Member Since: 15 Jan 2011 Location: Essex Posts: 431 ![]() ![]() ![]() |
What RPM was the engine at? it sounds like anti stall or idle jack
Jack |
I was doing about 25-30mph in 4th, so maybe about 1200 rpm? 2011 110 USW
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6328 ![]() ![]() ![]() |
sorry to jump in but could anyone shed a little more light on this anti stall - I know what it is and what its supposed to do but a) I thought this was a low ratio thing and b) at 1200 rpm......?
I presume this is a completely electronic thing and doesnt cause intermittent problems etc? if a problem then is it a re-map? |
I have got the hang of the gears, but they do clunk sometimes...I just accept it to be honest. I do tend to let the engine pull the vehicle along at low speeds, which could be why the anti-stall might kick in, but its still at 1500rpm or so... 2011 110 USW
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8217 ![]() ![]() ![]() |
if you put it in high 1st and pull away with a load - ie uphill or applying the brake or something similar to invoke the antistall are the symptoms the same as what you describe at speed in 4th? does it do it in all the gears?
dont touch the accelerator pedal when doing the above. anti stall works in all gears hi and low idle jack is low range 1st specific. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
It could just be the amount of play in the drive train, our roads are bumpy...doesn't seem to do it all the time whatever it is... 2011 110 USW
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5025 ![]() ![]() |
Bumpy roads....sounds more like throttle control
xatzhs Member Since: 12 Dec 2010 Location: Northumberland & Down South Posts: 258 ![]() ![]() ![]() |
I seem to get this jerking quite a lot... and also clunking gears. Am I just driving it like a complete rookie? (This is my first Defender) Any tips? |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 ![]() ![]() ![]() |
My defender does about the same. When driving in second at about 1500-1700 rpm and easing the pressure on the pedal it sometimes raises the revs a little bit - a few times I felt I had to apply the clutch
![]() Regards CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
This all sounds familure, although I can't recall where I read it, but it may be something to do with one of the fuses being blown. I think it was the brake light fuse, but can't be certain.
I'll see if I can find what I read, but it was quite while back. In the meantime, it won't take long to check your fuses. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
I can check the brake lights easily enough using the reflection in the house windows...
To be honest its such a subtle thing, but enough to be noticed. I think I only really noticed because a) its a brand new truck and b) I have been keeping a close eye on things due to problems with it having the tachograph in. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
