Home > Puma (Tdci) > Can't connect via the OBDII port
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Hi
I've got a problem where I can't connect any diagnosis tool via the OBDII port. I've tried several and the local garage tried theirs when I was in for an MOT and it doesn't allow a connection. It has power just won't connect.
Any ideas?
Thanks 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #781312 13th Jul 2019 7:48am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Any possibility that a previous owner has disabled it somehow for security reasons?
Post #781316 13th Jul 2019 8:00am
BenB8man
Might be worth a check of the fuses too, although I'm sure the garages have also done this. Embarassed
Post #781317 13th Jul 2019 8:06am
carrotbay
I’ll check them but I’d have thought that I wouldn’t have power if they had blown. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #781318 13th Jul 2019 8:13am
carrotbay
It was working fine. Have used it for a remap, fault code clearing, pump learning etc .. just won’t connect now. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #781319 13th Jul 2019 8:15am
BenB8man
Ah yes, if your reader takes it power from the port, it shouldn't be blown.
In my situation, I'm pretty sure the previous owner has installed my immobiliser to interupt the data lines, hence me mentioning that.
Any chance its taken damage? Maybe pushed one of the pins through the back?
Post #781320 13th Jul 2019 8:21am
carrotbay
Had it all apart and looks okay. I've managed to get my Foxwell to connect but still no luck with the BAS tool. Looks like it can connect but not via the high speed CAN. I'll contact Pete at BAS. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #781330 13th Jul 2019 10:21am
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
Hi.
I'm with the same problem, you can not connect my Nanocom, one day I stop doing it, I clarify that the Defender works perfectly.
I do not know where to start looking for the problem!
Greetings.
Post #781578 15th Jul 2019 1:48pm
NickMc
Try unplugging the dash and see if you can now connect?
Post #783349 27th Jul 2019 12:17am
