Home > Technical > Defender pulling left when braking
Naks
Hi everyone,
yet another issue cropped up on my Puma, only noticeable at highway speeds (>80kmh): when I brake, the car dives to the left.
Even if I hold the steering wheel straight, the car still does this.
What could be causing this?
Thanks --
Post #780810 9th Jul 2019 12:22pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Seized RH side front brake caliper?
Post #780813 9th Jul 2019 12:32pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Bearings / half shaft maybe? I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #780822 9th Jul 2019 1:44pm
bankz5152
+1 for this Instagram @defender_ventures
Empire Tuning - Agent
Post #780825 9th Jul 2019 2:04pm
AJC
Caliper, I know my o/s/f caliper is a bit dicky and this is what mine does, I just don't know what calipers to replace the front pair with yet
Post #780836 9th Jul 2019 2:58pm
Naks
thanks, it's going back to the shop on Thursday.
added to this is a rattling clutch. if it needs to be replaced, this will be the 4th time since 2010. Rolling Eyes --
Post #780837 9th Jul 2019 2:59pm
jst
opposite caliper to the side it going. most probably front, needs looking at. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #780841 9th Jul 2019 3:17pm
I have had a similar effect when the brake hose on the opposite side (the side it doesn't pull towards) has collapsed internally, but this is rare. As noted above, it is most likely that the caliper on the opposite side has seized.
Another possibility is that the pads on the side it pulls towards have worn to bare metal, but the noise would probably alert you to this.
Post #780850 9th Jul 2019 4:30pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I had this and it turned out to be a rear calliper with a sticking piston Euro-Leafing to infinity and beyond.....
Post #780860 9th Jul 2019 5:39pm
Roy5695
Just replaced my calipers pistons for stainless because of this problem.
These were the back ones once I managed to get the pistons to come out!
 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #780861 9th Jul 2019 5:50pm
jst
Roy - yours look pretty much same as my rear ones when they came off. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #780869 9th Jul 2019 6:59pm
Roy5695
Fronts weren’t too bad. The pistons were still corroded though which is not ideal for their correct functioning.
Instagram - @r22oyp
Roy
Post #780899 9th Jul 2019 9:53pm
Naks
the clutch is also rattling now, what's the latest news on that front?
it's been replaced about 4 times with the LR one since 2010, so maybe it's time for an aftermarket HD one? --
Post #780922 10th Jul 2019 7:13am
Roy5695
I swapped mine out with a new upgraded option from Luke at LOF. Complete kit including all the other bits required was around the £350 mark. I fitted myself so labour cost wasn’t an issue. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #780936 10th Jul 2019 9:19am
roel
My first guess will be the front brakes too, but also check your bushes front and rear. Roel
2003 90 Td5 (2009-now)
Post #780998 10th Jul 2019 5:56pm
