![]() | Home > Off Topic > Regular EU familiy car: dip the headlights enough? |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Have a look in your manual. You can change something at your headlight if I remember correctly.
Had a V70 (2016) myself. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4259 ![]() ![]() ![]() |
I worked on the roads dealing with traffic for over a decade and don't ever recall seeing a non UK vehicle using the beam benders or other stick on masks. It was something I actually noticed at the time and thought it odd. I go abroad regularly and always adaptedmy own lights for the continent. Well,.not anymore as I have Truck lights with a flat beam pattern
Assuming your lights have kick up, you should mask it off, but I think very few do and even less are picked up for it. 2007 110 TDCi Station Wagon XS |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 344 ![]() ![]() ![]() |
Thanks for the suggestions. Mine is a model year 2000, so perhaps not as fancy as the 2016 model that has a provision for adjusting the lights. I will have a look at the manual though, just to be sure! Defender 130 HCPU Td5 MY2000
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2724 ![]() ![]() |
No
In that case I assume you don't have xenon lights? No need for the manual, it's sticker time! ![]() |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
Dipping your lights is insufficient. Please cover or alter them - it's the decent thing to do ![]() |
Thanks for the feedback. What I forgot to mention, is that I don't expect to be driving at night. We will leave end of this week, and with the long days this time of year and small children, I am pretty sure we'll be back in our holiday home before dark. Defender 130 HCPU Td5 MY2000
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5264 ![]() ![]() |
what you can do, if you are over in the uk, is buy a set of UK lights from a breaker, and just swop those over, My cousin used to do the same thing with his cars, just buy the left hand drive lights in Germany. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
If you do follow Procta's advice, it's super-easy on a V70/XC70, just the two "blades" and a plug.
I use a bit of black tape cut to size, remember the "cut off" is the opposite way as it's a reflector... Best to do it, it's more considerate to other road users... You can see it on my motorbike headlight here ![]() Click image to enlarge Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
