Home > Off Topic > Regular EU familiy car: dip the headlights enough? |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Have a look in your manual. You can change something at your headlight if I remember correctly.
Had a V70 (2016) myself. |
8th Jul 2019 7:47pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4219 |
I worked on the roads dealing with traffic for over a decade and don't ever recall seeing a non UK vehicle using the beam benders or other stick on masks. It was something I actually noticed at the time and thought it odd. I go abroad regularly and always adaptedmy own lights for the continent. Well,.not anymore as I have Truck lights with a flat beam pattern
Assuming your lights have kick up, you should mask it off, but I think very few do and even less are picked up for it. 2007 110 TDCi Station Wagon XS |
8th Jul 2019 7:57pm |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 337 |
Thanks for the suggestions. Mine is a model year 2000, so perhaps not as fancy as the 2016 model that has a provision for adjusting the lights. I will have a look at the manual though, just to be sure! Defender 130 HCPU Td5 MY2000
8th Jul 2019 7:59pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2662 |
No bothers, and the old bill don’t enforce it. Of course if I dared to do the same I’d be pulled over within 100yds of the ferry.
8th Jul 2019 8:31pm |
In that case I assume you don't have xenon lights? No need for the manual, it's sticker time! |
8th Jul 2019 8:42pm |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
Dipping your lights is insufficient. Please cover or alter them - it's the decent thing to do |
8th Jul 2019 10:18pm |
Thanks for the feedback. What I forgot to mention, is that I don't expect to be driving at night. We will leave end of this week, and with the long days this time of year and small children, I am pretty sure we'll be back in our holiday home before dark. Defender 130 HCPU Td5 MY2000
10th Jul 2019 9:05am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5208 |
what you can do, if you are over in the uk, is buy a set of UK lights from a breaker, and just swop those over, My cousin used to do the same thing with his cars, just buy the left hand drive lights in Germany. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
15th Jul 2019 8:05pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
If you do follow Procta's advice, it's super-easy on a V70/XC70, just the two "blades" and a plug.
I use a bit of black tape cut to size, remember the "cut off" is the opposite way as it's a reflector... Best to do it, it's more considerate to other road users... You can see it on my motorbike headlight here Click image to enlarge Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
16th Jul 2019 7:15am |
