Home > My Defender > Baltic blue 110usw |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 587 |
No stopping me now
Mirror arms and crossmember done too Click image to enlarge |
30th Jun 2019 5:20pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
Great bit of work going on there, is there any more left to do 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
1st Jul 2019 8:13pm |
Great news with the 6 week break, that will give you a chance to catch up on all the maintenance on the vehicle's, can't beat a good tinker time 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
1st Jul 2019 10:18pm |
About two years ago a new head was fitted under warranty for no real reason and therefore injectors must have been removed. Anyhow recently I had started to get a funny sound when cold. Almost a popping and a bit of a tick. Last night I removed the engine cover and nipped up the injector clamps to the correct torque. They went round about 1/2 a turn to 6nm then another 180 to finish. What a difference no popping and the tick has gone too.
2nd Jul 2019 6:19am |
Side steps removed. Off side was a bit rattly. This was the result when I took end caps off a drilled the rivets out of the step plates
Click image to enlarge Absolutely crap |
8th Jul 2019 7:17pm |
I had a puncture a couple of weeks ago and checked the front drive members and they showed enough play to need replacing before ordering I thought I’d check the back. They need doing too. They were quite dry and dusty inside.
13th Jul 2019 8:57am |
Replaced all four drive members along with new gaskets and bolts. Drives like a different truck. The clunk has gone and the movement on the handbrake is now minimal. Very happy spannerer. All coming off again in a week or so as when I was in there i put a mic on all four discs and they are below the limits. New discs, pads and pins on their way.
15th Jul 2019 9:44pm |
Sure is a lot of happy spannering going on 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
16th Jul 2019 9:20pm |
Oh yes.
Took some kids from work to see this in Liverpool today Click image to enlarge Then went to lrparts to pick up all the parts for my brakes. Don’t know what the kids found more impressive the QM2 or the rolling chassis in the lrparts showroom. |
16th Jul 2019 9:26pm |
Nice pic of the QE2
The latter i would think 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
16th Jul 2019 9:31pm |
Click image to enlarge Box of dinitrol from Rejel arrived today. So with new brakes all round. Side steps to paint and refit and a full rust proofing job it’s going to be a busy week. |
19th Jul 2019 4:54pm |
Busy week. Dinitrol applied, side steps welded filled painted and tops reinstalled with rivnuts. Three corners with new brakes. Last one this morning then mud flaps back on and finished. Just a good wash required. Il post some pics when completed.
26th Jul 2019 6:17am |
Best laid plans and all that. One hub nut got jammed. Needed a new nut, stub axel, seals etc. Total cost about £20. But now I have new brakes all round and good for a good few thousand miles.
26th Jul 2019 4:45pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
Looking forward to seeing the dinitrol pics, you have certainly been busy 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
26th Jul 2019 5:18pm |
