![]() | Home > 130 > Td6 M57 in to 130 |
![]() My build thread http://www.defender2.net/forum/topic17615.html |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Sounds a great conversion. Also interested what the interior configuration is like with the unusual door positions. Do you have a thread somewhere?
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
No thread as yet, but think I may do one as I work on the car, a lot of what I will be doing will be of interest to others. 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
Kiwirich Member Since: 30 Jul 2019 Location: Toowoomba Posts: 1 ![]() ![]() |
Hello @Pilgrimmick
How is it after a few months ? Certainly keen to hear your thoughts. Looking into doing this in Australia. Kiwirich |
Unfortunately I am having some teething problems with the engine cutting out, think that it may be related to the ignition switch rather than the new engine, looking to replace it this week, so will be in a better position to give an honest appraisal once sorted.
The one problem I did have was vibration and noise, coupled with clutch slip. This was caused by going to a single mass flywheel and a composite clutch. I have since had the clutch changed for a heavier one that has sorted out the vibration/noise, but required servo assistance as it if a very heavy clutch. It now copes with the power, accelerating in higher gears without issues. It is 240bhp so quite some load when using the loud pedal! Once ignition switch swapped then may start new thread about build and ongoing developments. ![]() Click image to enlarge 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
Nice upgrade...
I was goin to do the same, but we found out my injectors were just no good any more. That is a very clean engine bay. Enjoy your new upgrade. Can't leave well enough alone |
Now getting more use out of it and learning the strengths.
Using fifth gear for almost everything once moving is almost as good as an automatic. More economical too,not quite sure by how much, but must be 20% or so. 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
Sounds like a good conversion...!
johnnyha Member Since: 08 May 2019 Location: London Posts: 41 ![]() ![]() |
would love to know how this is going as contemplating the same...
Unfortunately I have been having problems with the engine not running properly, slowly working through possible causes. Not my daily driver so has taken a back seat.
To be fair I wish I had not bothered or used another installer. A 3.9V8 would have been easier, cheaper and allowed me to run many thousands of miles before I was out of pocket on fuel. Think very carefully if you’re ally want the problems of all the non standard parts. 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
BajanRover Member Since: 12 Feb 2021 Location: Barbados Posts: 74 ![]() ![]() |
It must be fascinating to drop off your landy with the old engine and pick it back up feeling like a completely new and improved landy.....That's sick bro!! |
