![]() | Home > Technical > Aircon retrofit with a difference |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
Hello all,
I've got a bit of a plan for the 90. I fancy A/C but not the clunky bolt on under dash job a la factory. I currently have a D2 setup in the workshop minus evaporator. I plan to fit a modified heater box with evap and ducting to allow recirc. My question is, has anyone fiddled with aircon bits to make a working system out of bits and pieces? The wiring and switching side doesn't concern me. It more pipes and rads that might be more complicated to get right. So any experience shared would be great ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 ![]() ![]() |
I have used a retrofitsystem, i have a 2001 td5.
The condenser is in the normal position on the front, no fan, the front end is standard. The compressor is a little bigger so I have to un bolt it to change the centrifugal filter. The evaporator is in the rear on top of the back door. The air comes front the back and cools everything like an AC of a room no small vents heating your face, BUT it could freeze the ideas of the people on the back seat Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
I plan on extending the standard heater box with an evaporator on the cold side. Also a duct from the rear with a selectable flap for recirc or outside air
