Home > Maintenance & Modifications > Cubby box lid
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
Cubby box lid
I have a britpart cubby with the thin lid. I want to upgrade this to a comfier item.
Most suppliers sell a 50mm lid. At 5'7, will I see any benefit wit a 50mm lid?
I have seen that britpart supply a 'chubby' box with 80mm lid and wondering if this will be more suitable (or even too thick?).
My second problem with the 50mm is that everyone lists it as being made for the standard land rover box, does it differ to a britpart in terms of fitting a lid?
Thanks in advance.
Si
Post #779992 3rd Jul 2019 7:12am
donmacn
I can't comment on the height thing. That's obviously very individual, and will also depend on the height of the seat base (new or worn); whether any seat risers are fitted etc etc.
But I just thought I'd make a suggestion that might be easier and (maybe) cheaper. You could either take the existing lid off and take it to an upholsterer locally and ask them to add deeper foam; or find a piece of plywood, cut it to shape and ask them to make a thicker one up.
Before that even, you could get a couple of pieces of foam, stick them in some sort of cover and tape them to the existing box before deciding what suits you best?
Just a thought. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #780010 3rd Jul 2019 10:08am
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I bought one of these:
https://www.ebay.co.uk/itm/Land-Rover-Defe...2749.l2649
5 mins to fit, looks great Thumbs Up
Post #780013 3rd Jul 2019 10:41am
Mo Murphy
Make your own ! I made mine of layers of foam camping mat until the right height for me then covered in grained leatherette.
It's not rocket science.
50 Shades of Pennine Grey
Post #780014 3rd Jul 2019 10:55am
Mo Murphy
Post #780015 3rd Jul 2019 10:57am
donmacn
Ha! "make your own".... I did .... pics in the thread below, and it was carp! Embarassed
But I was complicating it with folds and a cut-out for the cubby key/lock.
I decided there was more to that than met the eye, hence the suggestion for an upholsterer. If it was a plain square, then I'd agree with you.
Layers of camping mat is a good idea though - build up in small increments till you find what suits. Thumbs Up I'll need to put a new foam lid on mine, as the sub locker has raised it too much for my 'home made template' to be comfortable. I'll go with the foam mat slices as a good approach. Donald
in the past..
Post #780016 3rd Jul 2019 10:59am
hank
Alternatively, cut some blocks/ply to size and block the cubby box up to the desired height from beneath
Or fit a locker box > 110 XS Double Cab
Post #780017 3rd Jul 2019 11:19am
landy andy
Fit a locker underneath the cubby box.
Raises the cubby, and provides secure storage.
Post #780019 3rd Jul 2019 11:26am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Raising the cubby up does seem the easiest and most logical solution.
Post #780022 3rd Jul 2019 11:39am
SimonDavies
Well I won't be making my own, due to the folds on the corners as mentioned (and shown) above.
I did overlook raising the box, I must admit. I will take a look at under cubby storage but I will want to do something with the lid because the britpart one is wafer thin.
Post #780026 3rd Jul 2019 12:45pm
Rashers
Can't comment on the Britpart compatibility, but the deep cubby top was the first thing I did when I bought my defender.
Got mine at the Peterborough show from Mobile Storage Systems. Looks the same as it did when I installed it.
I am sure you would benefit from installing one.
Post #780032 3rd Jul 2019 1:32pm
