Home > Maintenance & Modifications > Brake calipers |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 529 |
Straight forward to change a caliper, but looks like you need a new disc as well as sounds like its warped. always change the pair.
25th Jun 2019 2:53pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8021 |
the vibrating could be uneven wear or warped disc.
if a piston is stuck then yes caliper prob needs rebuilding/replacing. Could you force the piston in with a G clamp? or try taking disc out and pumping pedal to get piston to come out. on my 10 plate 72k miles neither of the two near side pistons would move without a massive amount of pedal pressure. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
25th Jun 2019 3:10pm |
Advanced Factors Site Sponsor Member Since: 06 Jun 2013 Location: Southampton Posts: 178 |
Hi Fabio.
Please use the link below to our website listing all options. https://www.advancedfactors.co.uk/rear-bra...1715-c.asp Regards Paul. Paul Redding +44 (0)23 8052 2760 www.advancedfactors.co.uk Site Sponsor for Aftermarket Parts |
25th Jun 2019 3:13pm |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 |
Thank you all for the replies.
I don’t think the disc is warped it only started doing it after I managed to change the brake pad. It has only done 90miles since. Does it matter that it has ABS? Does the calliper need to be different? Do I have to unplug the ABS? Fábio |
25th Jun 2019 5:05pm |
ignore the fact it has ABS, just change as a std caliper. it will bleed through the ABS system Cheers
25th Jun 2019 8:38pm |
Remember to put a clamp on the brake flexi pipe before removing brake pipe from caliper, less to bleed later.
25th Jun 2019 8:45pm |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 |
Don't know LRTV? Excellent series Take some time to browse these videos. https://www.youtube.com/playlist?list=PLLB...LmMGljp2K8 Joris Antares Treadwell, a MY06 110 Td5 in Chawton White |
25th Jun 2019 8:53pm |
Thank you all,
Ill try and do it then. Vogler thank you for the link to the videos. Fabio |
26th Jun 2019 5:05am |
