Home > Maintenance & Modifications > Brake calipers
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Brake calipers
Morning All,
I have been trying to sort out my brakes for a while now.
Last saturday i finally installed the last brake pad,pistons would not go back.
Now when i brake the car vibrates and the wheel is very hot, hotter then the other side.
I think the caliper needs replacing. is there a video on youtube that shows how to do change the calipers.
Also can anyone post a link of where to buy a set.
Does it make a difference that it has ABS?
Sorry about all the questions but it is doing my head.
It is for a 110 2.4 2011
Any help would be appreciated.
Fabio
Post #778890 25th Jun 2019 6:32am
htb2
Wales
Straight forward to change a caliper, but looks like you need a new disc as well as sounds like its warped. always change the pair.
Post #778954 25th Jun 2019 2:53pm
jst
the vibrating could be uneven wear or warped disc.
if a piston is stuck then yes caliper prob needs rebuilding/replacing.
Could you force the piston in with a G clamp?
or try taking disc out and pumping pedal to get piston to come out.
on my 10 plate 72k miles neither of the two near side pistons would move without a massive amount of pedal pressure. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #778959 25th Jun 2019 3:10pm
Advanced Factors
Site Sponsor
United Kingdom 1994 Defender 90 V8 Petrol SW Corris Grey
Hi Fabio.
Please use the link below to our website listing all options.
https://www.advancedfactors.co.uk/rear-bra...1715-c.asp
Regards Paul. Paul Redding
+44 (0)23 8052 2760
Site Sponsor for Aftermarket Parts
Post #778960 25th Jun 2019 3:13pm
Fabio
Thank you all for the replies.
I don’t think the disc is warped it only started doing it after I managed to change the brake pad. It has only done 90miles since.
Does it matter that it has ABS?
Does the calliper need to be different?
Do I have to unplug the ABS?
Fábio
Post #778966 25th Jun 2019 5:05pm
jst
ignore the fact it has ABS, just change as a std caliper. it will bleed through the ABS system Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #779010 25th Jun 2019 8:38pm
htb2
Wales
Remember to put a clamp on the brake flexi pipe before removing brake pipe from caliper, less to bleed later.
Post #779012 25th Jun 2019 8:45pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Re: Brake calipers
Fabio wrote:
...is there a video on youtube that shows how to do change the calipers...
Fabio
Don't know LRTV? Excellent series Take some time to browse these videos.
https://www.youtube.com/playlist?list=PLLB...LmMGljp2K8
Joris Antares Treadwell, a MY06 110 Td5 in Chawton White
Post #779014 25th Jun 2019 8:53pm
Fabio
Thank you all,
Ill try and do it then.
Vogler thank you for the link to the videos.
Fabio
Post #779029 26th Jun 2019 5:05am
