![]() | Home > Puma (Tdci) > ..deep clunk noise.. |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2656 ![]() ![]() ![]() |
Hi
Firstly odd noises travel around the truck so if you feel it coming from one area it may be the opposite. I had something similar and finally traced it to the panhard rod Bush. Could not see it on my own. I had to get the wife to wiggle the steering then it was plain to see. Otherwise get a pry bar and check all bushes from front to back. I'm your case I don't think it is a broken spring but again worth checking. Best of luck |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
Damper bushes would be a strong contender.
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Check the sleeves are still on the ends of the springs. If they aren't you can get a twanging noise as you drop off a kerb. Also check your steering damper hasn't worked loose on the chassis end. That makes some interesting noises. Don't ask me how I know
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20629 ![]() ![]() |
As Blackwolf mentioned, in particular the rear lower bushes. TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Ecco Member Since: 31 Oct 2015 Location: Kuala Lumpur Posts: 280 ![]() ![]() ![]() |
Thank you guys for prompt response..i will be checking those over weekend..
@markb110 Thats what i thought so, but then i drove truck very very slow(human walk speed) over small bump at parking, with open window and i can confirm that noise appear when truck goes over with front wheels, while rear wheels over same bump, produce no sound of any kind whatsoever.. |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 751 ![]() ![]() ![]() |
Let us know what you find, I'm hunting down my own deep clunk from below. Already bought shock bushings as those were already bad the last time I checked. Still, I suspect that there maybe other lurking clunk sources that need to be dealt with. I haven't changed out any bushings at all until this upcoming shock bushings.
Since this is the case, what are the bushes and components I need to check and / or replace? Sorry if it seems I'm hijacking this thread but could help you too, I reckon? ![]() |
neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 95 ![]() ![]() ![]() |
could be the top of the shock turret rusted out... a long shot I know but its a moisture trap and thanks to the covers, you dont get to see them much. I had one that had completley rusted out leaving a ring on the top of the shock that bade a heavy clunk if i did a speed bump at anything over 20. this was on an old 200tdi so yours might be a bit young for this to happen.
..here is the guilty one..im not sure how long these will last considering that they are so soft and i can squeeze them by hand easy..
Shock absorber bushings?
..yes..upper pair was gone, so i replaced all at same time..but im surprised after i realized how soft these are..
I've got replacement shock absorber bushings, both upper and lower, for all 4 shocks. Hopefully this will solve my clunking issues as well.
philippr86 Member Since: 08 Sep 2017 Location: Frankfurt Posts: 24 ![]() ![]() |
Hey guys,
just to make sure it's the correct part you are talking about... The ones in the photo (552819) are for the anti-roll-bar connections. The correct part for your shock absorbers is 552818. They should be quite a bit firmer. Here you can find the part numbers for the shock absorber bushes: https://www.advancedfactors.co.uk/ekmps/sh...shocks.png |
