Home > Puma (Tdci) > 2016 Puma - problems with 1st and 2nd gears AFTER service
Page 2 of 3 <123>
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Always worth a go. I'd also take it in and out of fixed diff a few times.
Post #778737 24th Jun 2019 8:54am
El Rey
Australia
Cheers - will do
Post #778740 24th Jun 2019 9:16am
Balvaig
Definitely worth a try.
You can drive in low range on any surface. The problem of wind up only occurs when diff lock is engaged - this is when you are best on loose surfaces.
Post #778743 24th Jun 2019 9:41am
El Rey
Australia
Aye - I assumed you were suggesting I use low + diff lock. Will give low a go Wink
Post #778752 24th Jun 2019 10:54am
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
possibly overfilled
Post #778883 25th Jun 2019 6:05am
El Rey
Australia
@Iktank Can I ask what overfilling does and what symptoms it exhibits?
Post #778885 25th Jun 2019 6:07am
El Rey
Australia
boxoftricks wrote:
Have you tried driving it in low ratio? I'm just wondering if the transfer box may not be quite aligned and causing issues in low gears that are more noticeable than high gears. A bit of a longshot, but maybe worth a check.
Found it was quite hard getting it into low range. Double clutched but had to fight the box for a minute or two to get it feeling like it was in. Then drove around in low 1st and 2nd for a bit, then back to high range. And 2nd gear felt even worse. I will give it another few days and if there's no improvement back to the shop it goes.
Cheers for the suggestion.
Post #779033 26th Jun 2019 6:09am
Balvaig
Beginning to think that your clutch or slave cylinder might be failing Big Cry It could be a coincidence that the symptoms started after a service - just sod's law.
It is a shame that it isn't something simple.
Post #779042 26th Jun 2019 7:21am
El Rey
Australia
Yes it's still weird that it happened immediately upon handing it back to me after the service, but there's not much to be said or done or fingers pointed until the problem is identified hey.
Post #779043 26th Jun 2019 7:25am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Sorted out your gearbox ?
Post #781447 14th Jul 2019 12:34pm
El Rey
Australia
I have not mate. 2nd gear still sticks like crazy when the gear box is cold, and then things improve as it warms up. But even then there's still the odd situation where it doesn't want to go in. I've taken to double and triple clutching in those cases, or just applying pressure until it clunks in.
I'm ordering a Shift-R Gear Shifter this month
https://bellautoservices.co.uk/store/puma-...r-shifter/
When I take it to the shop to have them fit it I'll leave the 110 there overnight and let them to take it for a drive first thing in the morning so they can definitely replicate what I'm experiencing. There's no way I can prove that it's something they did during the last service, and as someone said above it might just be sheer coincidence - so if there's something amiss then I'll just have to pay for it to be fixed.
One thing I did ask them to do last time was put a grease nipple into the pedal box and pump in some grease to combat the well-known squeaky clutch pedal issue. Well the squeak is gone but now I'm wondering if there's any way the action of the clutch has been affected in some way.
This is the procedure I'm talking about: https://www.4x4community.co.za/forum/showt...utch-pedal
Post #781449 14th Jul 2019 12:46pm
spudfan
Ireland
I would hazard a guess that the wrong gearbox oil was used. Happened to me with a 200 tdi. Could not change gear after a service. They had put the wrong specification oil in. Your mechanic may have used a good brand name but ask what the specifications on the bottle were. Also check the level of clutch fluid in the little container at the bulk head. It's a pain to open but if it is low on fluid your gear change will be anything but smooth.Going from high range to low range in a PUMA is the easiest of any Land Rover I have ever owned. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #782593 22nd Jul 2019 5:21pm
Iktank
Sorry not been on here working away.
Overfilling will cause difficulty in changing gears, even cause overheating as the oil does not have enough space to move around.
Common issue with the gearbox being overfilled, it does not have a level hole just a filling hole so correct amount must be put in - off the cuff I think it is 2.2ltrs.
I had a whining from my box as it was overfilled by LR
Post #782601 22nd Jul 2019 5:39pm
spudfan
Ireland
The gearbox takes GL4 spec. If GL5 spec was used it will react in a bad way with your gearbox innards. 1982 88" 2.25 diesel
Post #782617 22nd Jul 2019 6:35pm
El Rey
Australia
Thanks for the reply. I don't know what they used but this mob is one of the Defender expert shops where I live. They have 6-12 Defenders in their garage at any one time, as well as several series undergoing resto. So I have to assume they know what they're about with the oil. When I first took it back with my complaint, they also changed the oil out as a courtesy, so even if they got it wrong the first time you'd hope they didn't the second. I'll ask them what they put in to be sure.
I'll also be checking the clutch fluid in the morning - appreciate the suggestion.
Post #782844 24th Jul 2019 10:15am
Page 2 of 3 <123>
