![]() | Home > Td5 > Steering drop arm replacement |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 547 ![]() ![]() |
Tab washer should be bent up into the cut out shown in your 1st picture and down to lock the nut to the arm
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5943 ![]() ![]() ![]() |
Cheers, I was thinking about this last night, thinking how does this stop the nut undoing with only one side bent down. Hammer time! 1999 Defender TD5 110
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2735 ![]() ![]() |
The gap is normal, it’s a taper spline so as long as it’s done up F.T. then all will be well.
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
When I replaced mine I didn’t fold the washer over immediately.
I torqued the nut up every night for a few days first. Then folded the washer over. It’s a chamfered spline so ideally should never reach the top or it would rub when in action. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Thanks both.
If F.T = 178nm then yep. its F.T. That eases my mind. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
