Home > In Car Electronics > Hazard switch - light wiring
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
Hi Def forum,
I am in the process of rewiring the DEF. I purchased a tap turn unit (which are very good but pricey) - I am looking at a simple illuminated rocker switch to activate the hazards.
Any idea on how to wire the hazard LED so it flashes when on?
if is wire to an indicator it will flash when turning - where is this wired to?
TapTurn DIY kit - http://www.autowindow.com/choose-module
Post #777915 17th Jun 2019 7:53pm
Stiff1
I had PaulMc on here convert mine from the large Puma switch to a smaller one (that flashes when in use) matching all the others when I fitted the double din.
He built a 3 relay set up that was way beyond my capabilities, very knowledgeable chap, I would seek him out.
Post #778368 21st Jun 2019 7:17am
Martin
Site Admin
To use anything but a 4 pole latching switch requires the use of relay/relays to make/break the required number of circuits.
The hazard switch when "off" it feeds ignition supply to the flasher relay input, when "on" it feeds 12V to the flasher relay input and connects the flasher relay output directly to both sets of indicators and the warning lamp.
See https://www.defender2.net/forum/post751808.html#751808  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #778374 21st Jun 2019 8:11am
