Home > Td5 > Turbo bearing failing!
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
Just changed the engine oil on my 80k td5, which i will add gets done very 3000 miles! Noticed the end float is excessive and starting to score the housing.
I’ve never replaced a turbo on a td5 with less that 100k?
Obviously I will do some diagnostics but any ideas why it’s failed so prematurely ?
Alex
Post #777580 15th Jun 2019 11:14am
Alextd5
If anyone knows the oil pressure data for a Td5 that would help?
Post #777585 15th Jun 2019 12:18pm
lightning
80,000 isn’t really a premature failure, the turbo can last a lot longer but it depends on how it’s been treated over the life of the vehicle.
Post #777616 15th Jun 2019 5:45pm
bankz5152
Hardly an issue. Just change it.
Also 3k oil changes are excessive. Instagram @defender_ventures
Empire Tuning - Agent
Post #777619 15th Jun 2019 6:20pm
Alextd5
It’s been treated far better than most. First owner a friend had it serviced every 6k. I’ve done it every 3-4K using Morris oil and genuine filters. I religiously change the oil as it’s cheap and it doesn’t do any harm. Prematurely was the wrong word but it’s the only td5 I know which has had a pampered life suffer turbo failure at such low miles.
I have worked on td5’s for the last 6 years and only changed one turbo at 130k the rest were over 200!
If something fails I like to find out why, especially as this vehicle has been meticulously looked after it’s entire life! If it had been ramped and never had regular oil changes I wouldn’t be surprised or concerned about a cause.
I’ve been looking at the alive hybrid turbo but is it really worth it ?
What would you guys do, fit a new standard garret unit or upgrade it to vnt or hybrid ?
Post #777622 15th Jun 2019 6:49pm
Post #777624 15th Jun 2019 6:57pm
Alextd5
Thanks Jim!
We do have the data at work but not back until end of week and I’m keen to check it.
Alex
Post #777625 15th Jun 2019 7:12pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
If the Defender is shut off regularly after driving without several seconds for the turbo to spool down it can hasten the degradation of the bearings. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #777655 16th Jun 2019 12:58am
Alextd5
I’ve always allowed time for it to warm up and to spool down. I’m guessing the last owner did as he’s mechanically minded, I will ask. I’m going to check oil pressure today, if that’s fine and the oil feed is clear it’s down to the turbo alone and not a result of something else failing.
It has been remapped like a most td5’s and by a well known and respected tuner, so I’m confident it’s not related.
Post #777657 16th Jun 2019 5:43am
Alextd5
Oil pressure good. Slightly higher the spec at just under 4 bar at (cold) idle and 1.5 (hot).
Post #777712 16th Jun 2019 12:39pm
bankz5152
I youre considering an new turbo a hybrid is a big difference! Though needs mapping to suit.
I understand wanting to know why/how it failed but sometimes items just fail.
Sounds like everything that can be done has been done.
How do the oil feed and drain look? Instagram @defender_ventures
Post #777713 16th Jun 2019 12:47pm
Alextd5
Yes, I’ve been looking to upgrade the turbo for a while. Never expected for the old one to fail! Alive do a hybrid at £1300!!! Or allisport do one at £1000. Do all the hybrid turbos and vgt turbos require a boost control box?
I’m thinking of taking the intercooler off and cleaning it? Worth doing, I fitted an allisport one at Christmas! I think dropping the sump might be a bit anal? But then do the oil pump bolts come loose on late td5’s??
Best stuff to clean intercooler ? Normally use brake cleaner.
Alex
Post #777721 16th Jun 2019 1:49pm
bankz5152
Sump dripmis anal.
IC clean can be worth it i also cleaned my inlet manifold.
Try TD5inside, Jose is busy as hell but it was sub £1k for a turbo and map!
No you dont need a boost box for a better turbo but if you boost iver 18psi youll hit limp mode you want one but done need one. If yiu catch my drift.
They also do uprate MAP sensors (i have one) so no need for a boost box. Instagram @defender_ventures
Post #777722 16th Jun 2019 1:54pm
Alextd5
Will look into it. I noticed Alive offer a 12 month warranty on there’s and everyone else only offers 3!
Anything better to clean the intercooler out with?
I will flush with forte and drop the oil out again once new turbo fitted.
Post #777729 16th Jun 2019 2:52pm
bankz5152
I cleaned my Inlet with Mr Muscle oven cleaner.
When ever the turbo is changed the oil should be aswell. Good meadure to change again after 1k Instagram @defender_ventures
Post #777731 16th Jun 2019 3:06pm
