Home > Maintenance & Modifications > BlusSea ST range terminal eyelets |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
The blue sea screws are 10-32 which is about 4.8mm.
Have just wired up a blue sea box and just used the small red insulated ring terminals. If get half a chance I will check sizes tomorrow. Brendan |
11th Jun 2019 9:14pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20348 |
Thank-you Brendan.
Somewhere around 5 or 5.3mm I would have thought approximately. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
11th Jun 2019 9:27pm |
Slight correction.
Input studs for the positive and negative feeds in are 10-32 studs which are about 4.8mm The screws for fastening the outgoing wires are 8-32 which is about 4.2mm HTH Brendan |
12th Jun 2019 12:39pm |
Thank you Brendan. 👍🏻 $W33T $0U7H3RN $UG4R
12th Jun 2019 5:14pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
Yep, i used 5mm tube terminals on the power terminals and 5mm open barrel rings for the individual circuits and earths:
Click image to enlarge 02' 110 TD5 Double Cab Rebuild Thread |
12th Jun 2019 6:13pm |
Nice and neat. $W33T $0U7H3RN $UG4R
12th Jun 2019 8:16pm |
