![]() | Home > Maintenance & Modifications > BlusSea ST range terminal eyelets |
The blue sea screws are 10-32 which is about 4.8mm.
Have just wired up a blue sea box and just used the small red insulated ring terminals. If get half a chance I will check sizes tomorrow. Brendan |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Thank-you Brendan.
Somewhere around 5 or 5.3mm I would have thought approximately. Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Slight correction.
Input studs for the positive and negative feeds in are 10-32 studs which are about 4.8mm The screws for fastening the outgoing wires are 8-32 which is about 4.2mm HTH Brendan |
Thank you Brendan. ππ» Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Yep, i used 5mm tube terminals on the power terminals and 5mm open barrel rings for the individual circuits and earths:
![]() Click image to enlarge 02' 110 TD5 Double Cab Rebuild Thread |
Nice and neat.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
