Home > Puma (Tdci) > New rear Gwynn Lewis Propshaft but getting vibrations
Page 1 of 4 1234>
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Hi
Fed up with replacing UJ’s on the prop and a having a bit of play in the spline , I decided to buy a wide angle HD propshaft from Gwynn Lewis as they come highly recommended.
Anyhow, just fitted it and no sooner had I picked up drive I felt a reverberating through the floor, we’re talking 1mph .
Then took it for a spin on the road at around 30mph and the reverberating is still there when under load . It’s fitted the correct way with splined end facing forward, UJ’s and flanges were already fitted to the new shaft . It almost feels like I have to give it a bit more welly as well but that may be psychological, given it’s a heavy bit of kit !
Any ideas on what I could have done wrong ?
The old one clunked on take up but didn’t vibrate until you got to about 65mph ! https://www.instagram.com/hustynminepark/
Post #776591 7th Jun 2019 8:49pm
MK
Maybe a problem during the balance process? Puma 110" SW
Post #776614 7th Jun 2019 11:38pm
Bluericky
That had crossed my mind but I wouldn’t have thought it would show it at pick up speed.
When I popped the new one on I fitted the handbrake drum end first, when I went to do the axle end I realised I was 90 degrees out . Rather than take it off again , I popped the diff into neutral and rotated new prop so it would align .
Will that have made any difference? https://www.instagram.com/hustynminepark/
Post #776637 8th Jun 2019 6:59am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
No that won't have made a difference. Do you have play in either the output shaft/flange on the TC box or the diff flange? That can make em vibrate 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #776645 8th Jun 2019 7:48am
Bluericky
A small amount in both but i wasn’t particularly concerned about that as had far worse in the past
Perhaps i’ll drive it for a bit and see if it beds in https://www.instagram.com/hustynminepark/
Post #776650 8th Jun 2019 8:07am
jst
Take the prop off and drive it in diff lock see if it still vibrates. Refit nuts to hold drum on with no prop. For 10mi s work this will tell you if issue is with prop or either flange.
Vibration at 1mph? I am surprised anything is moving fast enough in drivetrain for that, engine related vibration for such low speed vibration, mounts? Engine or gearbox? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #776652 8th Jun 2019 8:19am
Bluericky
Thank you JST , it was absolutely vibration free with the old prop, the only way it could possibly reverberate going so slowly is if the new prop isn’t seated flush against the flanges , perhaps I unwittingly got a piece of grit in between when fitting !
I’ll remove and inspect ! https://www.instagram.com/hustynminepark/
Post #776656 8th Jun 2019 8:55am
landy andy
First thing to do is phone Gwyn. He’s a top bloke and will want you as his customer to be happy.
Andy.
Post #776661 8th Jun 2019 9:12am
Zed
What Landy Andy said.
Post #776666 8th Jun 2019 9:42am
You should try re-greasing it too. There could be an air pocket somewhere causing the grease to stay to one side or towards one side of the UJ’s. Mine (standard prop) is always a little like that after re-greasing then sorts it’s self out after a while.
Otherwise, I’d do as above and contact seller. TheThunder Rolls🇬🇧🇺🇸
Post #776674 8th Jun 2019 11:52am
Bluericky
Thank you , I was planning on giving him a call on Monday.
Funny you should mention the air pocket as the splined end of the prop bounced back when pushed in , I thought that may be by design https://www.instagram.com/hustynminepark/
Post #776697 8th Jun 2019 3:00pm
Bluericky
I had a great chat with Glynn , he went out of his way to be helpful and to try and fault find my vibration . If anyone is in any doubt whether to use his products I would say just do it , you don’t get after sales care like that from many companies nowadays!
I think we established that it’s hugely unlikely to be the new prop causing the reverberating but due to its extra weight it’s exaggerating an existing issue.
I’ve put the old one back on and it has appeared to eliminate the vibration , I have no idea why this could be? Any pointers welcome. I’ve pondered the following.
Transmission to chassis mounts
Centre diff failing (slight click on pickup, when turned by hand)
Handbrake drum (inspected but not sticking)
Rear diff failing
New halfshafts
Tyres are balanced and at 30psi
Checked that the diff lock is disengaged by jacking a front tyre, which it is.
If anyone can add anything please feel free as none of the above are particularly apparent faults
Please bear in mind that the reverberations are felt from 1mph upwards but only when under load (accelerating) . Also felt like I was having to give it a bit more oomph to get going but maybe psychological!! https://www.instagram.com/hustynminepark/
Post #777038 11th Jun 2019 11:49am
MK
I would try to do the following tests
1) 4 wheels off the ground and check if you can "see" the vibration
2) Remove front propshaft and see what happens
I this wide angle propshaft also designed with UJs out of phase? Puma 110" SW
Post #777059 11th Jun 2019 1:59pm
Bluericky
Hi MK
Thank you for the reply , I’ll try and get all four wheels off the ground , although I think I’d rather do it on a ramp rather than on axle stands .
The new prop is also out of phase but by a different degree to the genuine LR prop. The below photo shows the difference . The other ends are positioned squarely by the way !
Post #777085 11th Jun 2019 5:24pm
MK
Then I would mimic the LR phase and see what happens. Of course after you mark the original position.
I am just guessing. Puma 110" SW
Post #777086 11th Jun 2019 5:28pm
Page 1 of 4 1234>
