![]() | Home > Technical > Heater matrix |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5848 ![]() ![]() |
Disconnect the lever on the top of the heater box (under bonnet) and operate lever manually.
How does it feel? Can you hear it move/close flap? Does it stop the heat on test drive? |
As above. likely to be either a slipping cable or a broken cable.
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1876 ![]() ![]() |
... even a visual check? Note the position of the lever on top of the heater, move the cable, is the lever moving at all?
It's a really basic thing. I have some pics somewhere of a dismantled heater, which from memory shows how the lever/flap works - if that would be any use to you. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 ![]() ![]() ![]() |
I had a similar issue where is was very stiff to move the selector.
I removed the cable from the lever ontop of the heater box in the engine bay. Where the cable joins the lever there is a joint that should move so that the cable is always in the correct position to the heater matrix. This was very stiff. Some 3-in-1 oil and a little patience got this moving again. The cable was also a little stiff, so some 3-in-1 on that helped as well. I hope the above makes sense. Happy to take picture if it helps. |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5258 ![]() ![]() |
yeah lads get me some snaps, just so I have a good idea on what why and when, The old landy was spot on, but this one seems to be on constant warm or hot. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
I gave this a spray down and looked at the control on the heater box itself, on cold its pointing horizontal, then it moves to the driverside for the hot air, so I am suspecting something not right there. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Hey mate,
I mentioned pics a while ago - and then forgot ![]() I haven't got them here at the moment, but I did post them on this thread: https://www.defender2.net/forum/topic60066-30.html If you can, have a look and see if that helps? The flap in the box isn't sprung at all, so any movement will be coming from the cable. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
its moving, I am suspecting that the cable is seized. I will have bum up to my dad with his, just in case, mine is ok, and there is something else wrong Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
You have previously mentioned that the spacers were missing from the in cab controls. Did this bend / kink the cable too tight? Maybe worth disconnecting both ends of the cable straightening as much as poss and work it back and forth.
you know something, now that you mention it, I think I will buy the proper spacers and a new cable, in case that's been damaged as you say.
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
