Home > Puma (Tdci) > DGR Valve dead (or is it just sleeping?) |
Kez Member Since: 11 Apr 2011 Location: UK Posts: 271 |
I know, but I can hope can't I. Had the engine light come on, fault code on scan gauge was PO404, usual reset me thinks....
Only then did I realise I had not heard the usual cleaning noise for a while, you know, the one you get when you shut off the engine. So, double checked an no, silence when you turn engine off - is it dead (trucks done 36k). if so how much will it cost to replace, any idea of time involved, part cost etc.... |
23rd Jun 2011 4:43pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Sorry to hear that Kez.
Replacement from Dealer approx £120, eBay £75 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...95#vi-desc Alternatively you could go down the route of removing it and fitting a blanking plate:- http://www.defender2.net/forum/topic3115.h...alve+clean LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
23rd Jun 2011 5:27pm |
Cheers guys - saw the eBay part and looked under bonnet - cant even make out where it is, let alone see how to remove it - not helped in my case be lots of underbody wax all over the place left my before and after treatment. Any idea how much it would cost in labour (ie, how long someone who knew what they were doing would take).
Same question about blanking kit I guess, and in any case would the blanking kit work with a faulty unit ie, surly the engine light would still continue report a fault Last edited by Kez on 23rd Jun 2011 6:22pm. Edited 1 time in total |
23rd Jun 2011 5:50pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
No 3 in the diagram is the EGR valve assembly:
23rd Jun 2011 6:22pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
It's cooled so probably 2 hours I would say. if you look at the factory manual that will tell you where it is. it's not a hard job to replace and the detail is in the factory manual.
Ta lorryman, that very helpful, now i KNOW I could never get it out and back again
Same to you mike, but if somehow I doubt I could get it done in two days let alone two hours - many many years ago I had to replace a blown piston on a Triumph Spitfire (my first car!), was due to go on holiday with my girlfriend on the Monday, stared Friday night, finished 6 days later. We are no longer together (care or girl ) |
23rd Jun 2011 6:27pm |
Or you could forget all about it and give Gary at Alive tuning a call and get your Landy remapped ( mind and ask for the forum discount ) and you get the EGR closed upgrade included
http://www.defender2.net/forum/topic7064.html |
23rd Jun 2011 6:32pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
or pete from bas although you possibly dont want the the remap ?
regards steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
23rd Jun 2011 8:00pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1811 |
Try giving the unit a sharp tap with a hammer stale or similar (the wooden bit!) mine played up with poor internal connections, removed, stripped, cleaned & reassembled, but still needs a little tap now and again - saving for a remap and removal kit now.....
Keith |
23rd Jun 2011 9:01pm |
"Try giving the unit a sharp tap with a hammer" thats my kind of mechanics so just did as suggested, removed connector, sprayed a bit of WD40 around, put it back on, hit unit and guess what - its working fine again [/b]
24th Jun 2011 5:37am |
Good for you
If it is very dirty inside, hence sticking, would using a 2 Stroke Oil Mix help I don't know the answer, others might LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
24th Jun 2011 11:32am |
Would imagine adding a 2 stroke would increase emissions and hence extra soot, but what do I know - have seen a few debates on the subject, some on here, so far no definitive answer as far as I can see, just subjective opinions
24th Jun 2011 4:19pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
On the contrary - adding 2SO reduces soot in the exhaust gases since it makes diesel burn cleaner. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
25th Jun 2011 7:43am |
As I said, lots of people think this same, but as yet no one has pointed to and 'official' published research to substantiate that opinion. Surely if it was that simple fuel companies would add it at source for minimal cost and have a 'new' product that they could use for both a PR /marketing advantage as well as a premium product?
25th Jun 2011 8:40am |
