Home > Maintenance & Modifications > Rear LED brake light issue
Timo
Canada 1984 Defender 110 300 Tdi SW Alveston Red
Hi all
Just installed a set of LED brake lights on my 1984 110. Fairly basic job, black to black. Red to red and green to green for wiring. They turn on fine when pressing the pedal when the main lights are off. When I turn the side lamps or headlamps on they immediately go to full power as if I had the brakes on. No change to the lamps when braking if the headlamps are on
Any ideas on what is going on.
Tim Series II in pieces
1984 Defender 110 (3.5l V8 now 300TDI)
Post #775496 30th May 2019 2:35am
Despite the apparent obviousness of the wire colours, it sounds like the polarity is the wrong way around, which is important for LED's. It's difficult to know if it's the side or brake lights at fault so a bit if trial and error will be needed to work it out. Basically, swap each of the coloured wires with the black wire in turn to see which combination gives the correct operation. Darren
Post #775513 30th May 2019 8:04am
Martin
Site Admin
Sounds like the red and green should be connected the other way around.
The brake light part is coming on with the side lights, and so there's no increase in brightness with the brake pressed.
So red-green and vice versa. Try one lamp and see Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #775531 30th May 2019 10:26am
Timo
Thanks both, will give this a try. I also found on another forum that someone had the same issue with a bad connection. Will trouble shoot and post results
Post #775554 30th May 2019 1:28pm
Timo
Turns put it was an easy fix but not intuitive
Black to black
Green to red
Red to green
Now works as it should. Odd
Post #775759 1st Jun 2019 3:00am
