Home > Td5 > Bottle Jack |
People buy a disco 2 bottle Jack and find somewhere secure to keep it.
I buy Mercedes Sprinter bottle jacks, similar, but better. |
29th May 2019 7:55pm |
RANGER1312 Member Since: 04 Feb 2018 Location: Fylde Coast Posts: 125 |
Thanks Greeni, do the Mercedes Sprinter ones not fit in the seat box?
In what way are they better? |
29th May 2019 8:07pm |
They're more heavy duty. Not tried to fit it in my seatbox, one side is full of fuel tank, the other electrical science.
29th May 2019 8:39pm |
Ah makes sense I'll see if I can get the measurements for one and hopefully it'll fit
29th May 2019 8:46pm |
The standard LR bottle jack is exactly the same as that issued for the Disco 2. Perhaps your thinking of the Defender pillar jack, which is complete rubbish? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
29th May 2019 9:08pm |
Ihod Member Since: 07 Nov 2015 Location: Berkshire Posts: 165 |
Mercedes Sprinter and VW Crafter bottle jacks have the same saddle type axle support as a Disco or Defender jack and are usually rated by 1 or 2 tonnes higher capacity.
Very often available much cheaper on Fleabay..... Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
29th May 2019 9:49pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20561 |
Those Merc ones aren't any good if you have a flat tyre, which is kind of important! Due to the body size. KEEP CALM AND Drill ON
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
29th May 2019 10:11pm |
Hi LRA, thinking about it, it was a pillar Jack that was getting the mixed reviews.
Steve when you say body size do you mean size of the actual Jack i.e. it won't give you the height required to lift a defender? Do the Mercedes ones come in different sizes maybe? |
30th May 2019 6:00am |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
I think he means the body is taller so won't go under the axle if the tyre is flat. That's easily solved though, put your spare in front of the flat & drive up onto it, once the wheel is jacked up enough you can slide the spare out & swap them over - an old off roaders trick
30th May 2019 6:47am |
In my experience, it just works. I had a flat on the offside, i.e. the thicker end of the casing, of my old 90 and was able to squeeze a Sprinter jack under the axle casing to change the wheel. Darren
30th May 2019 7:58am |
Yes, the Merc version is a bit taller. That doesnโt mean itโs no good but can give you a few issues as mentioned above.
How much height they extend though and how they compare I donโt know. Personally Iโm quite happy with the LR version. KEEP CALM AND Drill ON ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
30th May 2019 11:01am |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
I bought a new sprinter one, picked up on eBay for ยฃ35 ๐
30th May 2019 12:51pm |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 333 |
The Merc jack is just the right size to fit in the battery box, and the handle (borrowed from a trolley jack) fits neatly alongside.
No problems lifting my 110 with a flat. |
31st May 2019 9:43pm |
Thanks for the replies guys, really appreciate it
Good to know that it will fit in the seat box and thanks for the heads up on the off roaders trick Last edited by RANGER1312 on 8th Jun 2019 9:19pm. Edited 1 time in total |
1st Jun 2019 2:13pm |
